B-series Mounts in a 98 ek coupe????
Old Feb 9, 2003 | 03:22 PM
lowcivex's Avatar
Default B-series Mounts in a 98 ek coupe????
I was wondering about which mounts i need in a 98 civic. It was automatic which makes matching up mounts for a b-series even harder. Can anybody help me on this. Which ones should i get and out of what year or should i buy a hasport mount kit. Thanks for your help.
If anybody has any of the mounts i need hit me back at lowcivex@yahoo.com
Old Feb 10, 2003 | 06:00 AM
Civic's Avatar
Default Re: B-series Mounts in a 98 ek coupe???? (lowcivex)
all that you should need are a set of 99-00 si mounts
Old Feb 10, 2003 | 09:21 AM
Trey's Avatar
25 Year Member
Default Re: B-series Mounts in a 98 ek coupe???? (Civic)
http://www.jspectuning.com/6gen
Old Feb 10, 2003 | 10:16 AM
lowcivex's Avatar
Default Re: B-series Mounts in a 98 ek coupe???? (Trey)
thanks that site really helped.
Old Feb 10, 2003 | 11:53 AM
Stroker
Guest
Posts: n/a
The lower mounts are gong to give you a little problem. There is a metal tab on both sides that will have to be removed, before you can install the mounts from a 99 and up Si.
Old Feb 10, 2003 | 12:17 PM
lowcivex's Avatar
anything about the automatic tranny mounts. Will a 5 speed b series mounts bolt in if not what kind of modification is required
Old Feb 10, 2003 | 04:02 PM
Nameless RB26's Avatar
That site has the wrong part number for the thing you need though (rear tranny bracket).
The part number for the rear tranny bracket is: 56027-S04-N10
It says "rear tranny mount" ... but you need the bracket, not the mount. Just trying to help you out, because I was using that page when I did my swap.
I wish they'd change that..
Old Feb 10, 2003 | 08:37 PM
madtownhonda's Avatar
Default Re: B-series Mounts in a 98 ek coupe???? (stroker)
It's no problem...just use the rubber mounts from the chassis. You don't even have to remove them.
As you can see.....they are the almost exactly the same. You need to use the one on the right, which is the stock one. This applies only to the Front trans mount and A/C mount.
Old Feb 10, 2003 | 09:21 PM
Default Re: B-series Mounts in a 98 ek coupe???? (madtownhonda)
I used the one on the left with mine.. just grinded it down a little on a grinder.
Old Feb 10, 2003 | 09:31 PM
Default Re: B-series Mounts in a 98 ek coupe???? (Nameless)
Well...I suppose if you want to do it the hard way then you can whip out the grinder and go to town. I would prefer just to do the easier thing.
Old Feb 11, 2003 | 06:36 AM
Trey's Avatar
25 Year Member
That's the rear tranny bracket I used and it was fine. Wonder if Honda changed their numbers???
Old Feb 11, 2003 | 11:46 AM
When I took that number to honda, they told me it was bogus. I dunno if honda changes their numbers, if so, that's wierd of them...
Old Feb 11, 2003 | 09:17 PM
deviant1's Avatar
The front tranny mount? on EK civics, can you reuse the automatic front tranny mount with the 5 speed B-series front tranny bracket?
Old Feb 12, 2003 | 07:46 AM
lowcivex's Avatar
Default Re: B-series Mounts in a 98 ek coupe???? (deviant1)
thats agood question. I was wondering the same thing.
Old Feb 12, 2003 | 09:58 AM
SC61HB's Avatar
Hey Trey, I just recieved my 2 mounts for my swap (rear tranny bracket and driver's side mount) As far as the driver's side mount, it doesn't look the same as in the pic you show on your site. This is a rough drawing of the side view of the mount I got. It has the same part number as you listed. If you ask me, it looks like it has an extra hole at the very bottom
Let me know what you think
Old Feb 12, 2003 | 10:22 AM
Default Re: B-series Mounts in a 98 ek coupe???? (zgrieger)
You have to remove the timing belt cover to install it. You'll see that there is another bolt underneath the timing belt cover.
Old Feb 12, 2003 | 10:24 AM
SC61HB's Avatar
Sigh, thank god I don't have to return it. THANKS for your help. I understand know.
Old Feb 12, 2003 | 10:50 PM
lol. That's a mount isn't it.... not a bracket..
Old Feb 13, 2003 | 01:36 PM
SC61HB's Avatar
Yeah, that's a rough drawing of the driver's side engine mount. The part you have listed on your site.
jestin91
Dec 19, 2012 08:29 AM
FLYBOIR
Jan 1, 2010 09:42 PM
sickerhatch
Feb 28, 2006 06:27 PM
JDM Like Whoa
Feb 24, 2005 08:39 PM
Wazup
Nov 11, 2003 12:53 PM
