d16z6 ... obd0 or obd1 ?
ok i know that everyone says go obd1.
how am i limited if i use an 90 teg ecu with a vafc and stay obd0?
what are the advantages of going obd1?
i know engine management is a key but im not shure if im going all out on it like i think i can pull some decent number's with the obd0 setup and then i can always go obd1 later on.
i have heard of the obd0-obd1 harness what other mod's go along with this harness? i would like this thread to be as imformational as possible. i tryed search but if anyone knows any good threads on this subject please post a link
thanks alot
-larry
thanks alot
-larry
Honestly.. if you are patient and dont mind the wiring.. just do the OBD1 swap, you will get the correct fuel/spark maps that the z6 was designed for..
But IMO, not all of us have that kind of time, and if you just use a vtec controller with say a pg7 ecu, and tune the ****** on the dyno, you will probably be just fine sticking with obd0..
Jeff Frank
Jeff Frank
Yeah PG7 I agree with that. I have this set up. PG7, V-AFC and a Z6. I've been pretty happy with it. Dont use the PR4 it has a lower rev limit thats the only down fall, if going with ECUs and you already have it use it, but its the same rev limit as the PM6. While the PG7 is 7200. I know for a fact that OBD1 would be a little faster but not by alot. Is it worth it to you to do the wiring conversion?? I just made a jumper and it took about 6hrs and it suxs or do you have the $$$ for a jumper about 150.00. OBD0 electronics (diz mostly) are know for going out but there atleast 12 years old so thats no too bad.
VAFC can take care of fueling and vtec activation but rev limit and ignition maps are still holding back the overall performance of the motor.
my recomendation is to have the PR4 chipped. (many specs exist including PM6/PM7 or PR4 aftermarket program which will work) this can take care of the ignition maps and higher rev limit.
What are the advantages of going obd1?
http://www.geocites.com/kurtsi_on/page10.html there is the wiring diagram for OBD0 to OBD1
:update: ive had this setup up and running for about a year and i cant say there is anything better! ive been very happy with the results ive had so far with it. i havnt done any head work this year but i expect to pull some very good numbers next year with headwork. (cam, springs, retainers, mild port exc) ill keep you guys updated!
sohc
sohc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote"><VAFC can take care of fueling and vtec activation but rev limit and ignition maps are still holding back the overall performance of the motor..</TD></TR></TABLE>
i was told by my friend who owns a shop and has been racing for 26 yrs and have been tunning hondas for over 12 yrs told me the following
well one thing people dont know is that Honda Engines normally reach Full ignition timing advance around 4100 rpms and the rest relies on actual Air/Fuel maps
the ignition advance was design to maximize engine performance on low and mid range while driving on city etc... on WOT over 4100 rpms the engine its fully advanced and running on programed Fuel maps
DOHClessEF-9
12
Apr 21, 2005 06:07 PM
