Type R Sway Bar Runnbing Brake Lines
Old Feb 9, 2003 | 01:16 PM
bluecivic107's Avatar
Default Type R Sway Bar Runnbing Brake Lines
Anyone experiencing the Type R Sway Bar rubbing on the brake line metal brackets on the Lower Control Arm. I have a GSR with a 22mm Type R sway Bar with a kit similar to BSQ.
Any responses would greatly be appreciated,.
Old Feb 9, 2003 | 01:22 PM
IC x Prince's Avatar
New User
Default Re: Type R Sway Bar Runnbing Brake Lines (bluecivic107)
mine is really close to the ABS sensor wire, not my brake line (maybe that is what your talking about) mine barley clears that thing.
Old Feb 9, 2003 | 01:41 PM
neo1z's Avatar
Default Re: Type R Sway Bar Runnbing Brake Lines (UltraPrince)
why did you post this twice?
Old Feb 9, 2003 | 02:37 PM
Default Re: Type R Sway Bar Runnbing Brake Lines (neo1z)
Sorry for the double post!!
Old Feb 9, 2003 | 03:50 PM
Fuuma0083's Avatar
you might have put the swaybar the wrong way.
Old Feb 9, 2003 | 04:35 PM
Tweakmeister's Avatar
Default Re: Type R Sway Bar Runnbing Brake Lines (Fuuma0083)
i cut my brackets (black metal ones)
you might have on wrong too...
Old Feb 9, 2003 | 05:21 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Type R Sway Bar Runnbing Brake Lines (Tweakmeister)
make sure that the ends of the sway bar bend upward, like this ^. If it dips down on the ends then it's upside down.
battmancjz
Jun 3, 2016 06:19 AM
honda_coupe
16
Dec 8, 2007 09:00 AM
hamburgler
15
Feb 20, 2007 04:42 AM
bluecivic107
Feb 10, 2003 04:56 PM
