440cc injectors too big for fully built NA/Hondata GSR? Sgt?
Old Feb 9, 2003 | 11:13 AM
TimoneX's Avatar
New User
Default 440cc injectors too big for fully built NA/Hondata GSR? Sgt?
OK the last thing I need(ed) for my car before I can put it back together, break-in, and tune is injectors. I can get a great deal on new RC engineering 440cc saturated injectors. Are these going to be too much for my 85mm b18c w/ 12.5:1ish compression and Crower 63403 cams? I'm using a P28/Hondata S200 computer BTW. I have an adjustable FPR, so I'm thinking I can just lower the pressure and run a fairly low duty cycle. I've not gotten my Hondata tuned though, so I don't know. Anyone have any thoughts...constructive thoughts?
Old Feb 9, 2003 | 11:16 AM
Ekasey's Avatar
Default Re: 440cc injectors too big for fully built NA/Hondata GSR? Sgt? (TimoneX)
well i run 310's on my low compression b20 (kinda built for turbo but i run it NA) and those are sitting so low on the duty cycle so in other words 310's wold prolly be more then enough
Old Feb 9, 2003 | 11:31 AM
joe_bocc's Avatar
Default Re: 440cc injectors too big for fully built NA/Hondata GSR? Sgt? (eLusive ek4)
How much power do you think you have? RC engineering has an online flow rate calculator so you can find out what size injectors you need. If you don't feel confident using that, you should just call RC Engineering and talk to some one who knows what they are talking about. I don't think that 440 will be too big because you have a lot of things done that might require the bigger injectors.
Old Feb 9, 2003 | 11:42 AM
TimoneX's Avatar
New User
Default Re: 440cc injectors too big for fully built NA/Hondata GSR? Sgt? (joe_bocc)
I was just under 200whp before sleeving w/ JDM ITR pistons. I'll be hoping for somewhere around 220-230whp after tuning. I did go through their flow rate calculator when I was thinking 370cc injectors. I don't think that'd give me too much headroom, though I'm not sure what else I can/will be adding to this setup.
[Modified by TimoneX, 12:44 PM 2/9/2003]
Old Feb 9, 2003 | 11:49 AM
TimoneX's Avatar
New User
Perhaps, but how high do you rev that thing? I had a Greddy A/F gauge on my GSR and it would lean out quite alot near my 9300RPM redline. It runs short on breath right around 9k, so I'll probably have it lowered to 9k RPMs when I have it tuned, but after the x-over at 6k it starts getting pretty thirsty. This is when I'd have concerns about 310 or even 370cc injectors not spraying enough fuel.
Old Feb 9, 2003 | 12:14 PM
canuck-mx6's Avatar
Not at all, Hondata will make them work like your stock 240 cc/min injectors. That is what I am running!
Old Feb 9, 2003 | 12:19 PM
fukaintmuven's Avatar
Default Re: 440cc injectors too big for fully built NA/Hondata GSR? Sgt? (canuck-mx6)
i have a fully built LS/Vtec and runb 310s... theyre a pain in the *** without tunning cuz my car runs like dhit... i should be alright afta tunning... plan on switching to 270cc for now
Old Feb 9, 2003 | 12:22 PM
TimoneX's Avatar
New User
Default Re: 440cc injectors too big for fully built NA/Hondata GSR? Sgt? (fukaintmuven)
May I suggest the '97+ Prelude injectors? They're 290cc and saturated.
Thanx guys, I think I'm gonna go ahead and jump on the 440s.
Old Feb 10, 2003 | 12:21 PM
TimoneX's Avatar
New User
Beautiful car canuck-mx6.
Old Feb 10, 2003 | 12:46 PM
sgT's Avatar
sgT
keep the pressure around 40-50 psi so the spray pattern remains good.
otherwise with hondata you can use 440s with no problems.
i get 40mpg on my motor with 440. going to 550s soon most likely
Old Feb 10, 2003 | 12:50 PM
servion's Avatar
There will be absolutely no problem there. Actually, if you get that size then you will have a little "breathing-room". You can certainly tune the car to use those fine, and your injectors may simply run at a low duty cycle. If you get different injectors that flow less fuel, then it will be more difficult to get that fuel later if its needed. If you can get a good deal, they will be perfect.
Old Feb 10, 2003 | 01:06 PM
TimoneX's Avatar
New User
Default Re: 440cc injectors too big for fully built NA/Hondata GSR? Sgt? (servion)
Thanx again guys. They're new RC SL-440s. RC Engineering identified these as thier part for a Ford Mustang, but said they'd fit a Teg fine with minor modification to the fuel rail. Since they're being sold 8 at a time I believe they are Mustang injectors. I'm getting them for $260 and can hopefully resell 4 and recover most of the cost. Yes I am cheap.
B18 rider
Aug 8, 2008 10:51 AM
madman604
Feb 11, 2003 09:45 AM
ALLMOTOR18
Jan 30, 2003 04:25 PM
CM-R
Jul 6, 2002 12:36 PM
b18cTurbo
Feb 26, 2002 11:37 AM
