I was very bad today
Kicker midbass. I will run from 200 down to 60, I hope. It feels beefy, like a baby sub.
I have only had 4 hours of sleep, but I am on a mission.
I hate hiding the crossovers. They look very good. I saw the diamond audio amps in person also
I would hang it on my wall. Who needs paintings?
[Modified by vteg, 10:51 AM 2/9/2003]
I would hang it on my wall. Who needs paintings?[Modified by vteg, 10:51 AM 2/9/2003]
Yeah the amps were one of Streetwires greatest ideas
then they had issues....Mitek got the wire division...didnt need
another amp line. Beautiful design and construction.
Cool, didn't you just show your alpine component install a month or two ago?
I am my car's bitch. Nothing was accomplished. The kicks and diamonds are in position, they just need to be secured and connected, but it is cold.
Until next week.
Until next week.
Please respond with how those kicker midbasses sound ! Are you throwing the rest in custom kicks or q-logics?
how are you crossing over the midbass, amp or passive?
and lastly...do you think i could fit the 8" version of the resolutions in the door
-rage
??-rage
-rage
??-rage
The diamonds will go in q-logics.
The midbass will be active. I planned on crossing it through my head unit by switching it to 3way mode(alpine 7998) but the high pass will not go below 1khz. I put it back to normal f/r mode and will use a combination of the headunits crossover on the low end and the amps on the highend. I plan on crossing around 200-60 when I have a sub. Right now I will let it play down to 40 at least.
I think you can get 8" in there with some sheet metal cutting and door panel modifications. 8 inch midbasses would be sweet.
[Modified by vteg, 4:23 PM 2/10/2003]
Two weeks later, and I am finally done
I gave up and cut the sheet metal
I must say the terminals on the kickers are nice, if they were subs. Those posts want to ground on everything. After cutting the door I taped everything close to the terminals and taped the terminals themselves also. I listened to them crossed at 50hz with 24db/oct. At high volume it got muddy and distorted. 63hz improved the situation. At 80 I have not been able to distort them yet. I will try 12db/oct when I go back outside.
I still have no sub but the system sounds much better. I am surprised that those little guys can shake my rear view.
I must say the terminals on the kickers are nice, if they were subs. Those posts want to ground on everything. After cutting the door I taped everything close to the terminals and taped the terminals themselves also. I listened to them crossed at 50hz with 24db/oct. At high volume it got muddy and distorted. 63hz improved the situation. At 80 I have not been able to distort them yet. I will try 12db/oct when I go back outside.I still have no sub but the system sounds much better. I am surprised that those little guys can shake my rear view.
I am happy with them. Are you going to do 8 inch with the kickers?
I need to listen to them some more. I don't think they can really handle 100 watts inside a door though.
