Integra brakes + HX 14" rims = ???
Old Feb 9, 2003 | 12:00 AM
agent_noman's Avatar
Default Integra brakes + HX 14" rims = ???
I have stock Civic HX 14" rims on my HX chassis. Though I am soon picking up some nice 17's :D , I prefer to keep these stockies with my Azenis tires for the road courses.
I am swapping the rear brakes to GSR rotors and calipers and am thinking about doing the same to the front.
What I need to know is whether the HX rims will fit over the integra rotors and calipers. If it is an offset issue, I might be able to use spacers. Also, if anyone knows how large of an aftermarket rotor will fit under the 14's I'd like to hear it.
Thanks in advance.
Larry
Old Feb 9, 2003 | 05:52 AM
VTECVillain's Avatar
Default Re: Integra brakes + HX 14" rims = ??? (agent_noman)
They will rub in the back, not sure about the front but I doubt it. My friend had an 00 Si and tried using the HX wheels. They barley fit in the back and after driving around the block, the caliper grinded a nice ring on the inside about 1/16" wide and deep.
Old Feb 9, 2003 | 06:58 AM
deez92's Avatar
Default Re: Integra brakes + HX 14" rims = ??? (VTECVillain)
the rears fit fine on my hatch. the front i had to grind alittle of the calipers.
Old Feb 10, 2003 | 07:53 AM
integra6650's Avatar
14" will definately not rub in the back i had them on my teg when the nice liittle car thieves put them on my car in trade for my swirlies "Bastards(shaking my fist)"
Old Feb 10, 2003 | 10:19 AM
Default Re: Integra brakes + HX 14" rims = ??? (integra6650)
So is there a difference in the size of rotor or caliper on the 99-00 Si as opposed to the Integra? I know that the caliper dragged the inside on my friends 00 Si and his brakes are stock. If he would've used a spacer, probably around 1/4" it would've cleard but just barely.
Old Feb 10, 2003 | 10:56 AM
Thanks for the replies.
So do you think if I use a spacer on the front it should clear?
Haha, man at least they left you some real rims instead of ghetto hubs...okay, sorry.
Old Feb 10, 2003 | 11:22 AM
deez92's Avatar
yes it will clear, but i would take alittle off the caliper insted
Old Feb 11, 2003 | 08:28 PM
Cuong-nutz's Avatar
Default Re: Integra brakes + HX 14" rims = ??? (deez92)
If memory serves me right, if i were to do a rear disk conversion my vx wheels wont fit or is it a tight fit? i cant remember what size the rotors were either
Kyles ej1
44
Mar 21, 2005 09:47 PM
4drferio
11
Nov 1, 2004 08:52 AM
mykejamison
Jul 6, 2004 08:19 PM
airon
May 10, 2002 09:37 PM
Black R
Apr 3, 2002 02:04 PM
