starter or battery?
Old Feb 8, 2003 | 11:55 PM
pr0jektdc2's Avatar
Default starter or battery?
okay im really getting tired of this problem...sometimes when i try to start my car it will just click but not start it will take anywhere form 10-30 trys before it starts up...there lighting and everythign and my terminals are connected right and theres no corrosion on any of it...i highly doubt its my alternator cuz u cant here it spool up or try/struggle...i had my battery tested and its good...so could it be my starter? anyone have pics of one? and how hard is it to install and mow much am i looking at for a new one or refurbished one? thanks alot guys...
Old Feb 9, 2003 | 12:03 AM
pr0jektdc2's Avatar
Default Re: starter or battery? (pr0jektdc2)
BUMP BUMP BUMP!!!!!!!!!!!!!!!!!!
Old Feb 9, 2003 | 12:10 AM
pr0jektdc2's Avatar
sumone please help!.!.!.!.
Old Feb 9, 2003 | 12:26 AM
aznmc16's Avatar
my starter just died on me a few days ago. i was at school so i had to get it fixed at a local garage. it cost me $220 installed for a rebuilt one.
it isnt' that hard to install. you can pick up an aftermarket one plus trade for like $60. installing it.. its under your distributor.. and its a long oval shaped black metal piece.. like an oversized soda can. i rmemeber there was 1 big long bolt that seeemed a lil hard to get to and like one or two more lil bolts.
Old Feb 9, 2003 | 12:27 AM
mckenzie's Avatar
it's one of your ground wires..try the one by your intake filter [or where the stock one should be] thats all i can say or take ur starter to autozone and have them test it
Old Feb 9, 2003 | 12:52 AM
DA MUGEN 1's Avatar
Default Re: starter or battery? (egMee)
(need more info)Does the clicking noise sound like it is coming from around the dash or in the engine bay?
Old Feb 9, 2003 | 02:11 AM
97hb's Avatar
Check the grounds. Also check the wire coming from the battery to the starter, it might be loose.
Old Feb 9, 2003 | 02:20 AM
miketegra's Avatar
Default Re: starter or battery? (97hb)
I say: "starter"
Had the same problem on a 94 GSR.
Everything worked fine but when I turned the key to start it, it would just click until magically it would decide to turn over.
I replaced the starter with a reman. unit from AutoZone or NAPA and the problem went away. And I did check the connections before I replaced the starter.
Old Feb 9, 2003 | 10:35 AM
GSRaCeRbOI's Avatar
after checking the wiring (power wires, ground wires, corrosion, etc)... I think its the starter... when the starter went out on my 95 it did the same thing.. I'd turn the key. hear a click (solenoid) but the motor wouldn't turn over... I would keep trying or wait a while then it would start up... replaced the starter and it has been fine up until the accident...
Old Feb 9, 2003 | 10:57 AM
WatchemSpin's Avatar
What happens is your starter carbons are out, they are what crank your engine to turn on, just take out your starter (only 2 bolts) and take it to an alternator shop, it should only cost like 40 bucks to fix it, the same thing happened to my starter...
Old Feb 9, 2003 | 12:07 PM
natrl's Avatar
i had the exact same problem last week...i was told that it was my starter, so i was about to buy a new starter....but i decided to double check the wires before i bought one...all i did was check the wires and i loosened and tightened the starter cable (its on the starter) and i had no problems since then
SiB16A
Jun 11, 2006 12:37 PM
01-0720
Feb 3, 2005 04:23 PM
rafiq7
Dec 14, 2004 07:46 AM
See Are X
Mar 6, 2003 10:08 PM
