b 16 question
Old Feb 8, 2003 | 08:50 PM
eknine's Avatar
Default b 16 question
isnt there a pre obd b16 that was made in japan? what ecu did it use? a PW0
Old Feb 8, 2003 | 09:07 PM
Redline130's Avatar
Default Re: b 16 question (eknine)
PW0 or PR3
Old Feb 8, 2003 | 09:16 PM
eknine's Avatar
Default Re: b 16 question (cyber13)
thanks.. so there is a pre obd jdm b16 right?
Old Feb 8, 2003 | 09:27 PM
Redline130's Avatar
Default Re: b 16 question (efzero)
sorry but thier is no such thing as pre OBD on any car with an ECU and a oxygen sensor. Everything up until 96/97 was the basic or sometimes refered to as OBD1.
So if I'm reading this right, 88-91 civics/crxs are OBD1??? OBD1 cars started in 92.
Old Feb 8, 2003 | 11:04 PM
paybac4223's Avatar
88-91 crx/civic are considered OBD0...
Old Feb 9, 2003 | 02:37 AM
chad174's Avatar
Default Re: b 16 question (paybac4223)
yes, the 88-91 crx's/civics are obd0. ob 1=92-95. obd2=96-02
Old Feb 9, 2003 | 09:20 AM
Camshaft's Avatar
Default Re: b 16 question (chad174)
PR3 , PW0 are OBD0 or Pre obd computers
Old Feb 10, 2003 | 07:11 PM
eknine's Avatar
Default Re: b 16 question (Camshaft)
thanks for all the help, here is whats up.. ok i have a ek first of all, but im doing a swap in a crx for my friend, the motor is a built 99 gsr, and a few of my friends said it would be easier to go obd 0 since i didnt have the harness for the motor, so i got a pre obd dist, and ecu (pr3), and i have the injectors.
so my question, am i close enough to having all the parts for obd0 or should i sell the stuff i have and go obd 1, if i go obd 1 dont i have to get a gsr wiring harness?
HELP please
Old Feb 10, 2003 | 07:23 PM
bryant's Avatar
For converting to any OBD you need:
-Alternator
-Distributor
-Injectors
-Wirring harnes
-ECU
of the OBD that you want to convert to.
*its called non-OBD, not pre-OBD*
BTW, I hope I got all the parts above right
Old Feb 11, 2003 | 09:03 AM
DJ_SaNdOz's Avatar
as far as i know there are 2 obd1 designations, i can't for teh life of me recall how they are diferentiated (sp?) the cars that are referred to as obd0 are actually teh 1st gen of obd1. if it's got an ecu that spits codes it's got a form of "on board diagnostics"
Old Feb 11, 2003 | 10:16 AM
APEXI Si's Avatar
Default Re: b 16 question (dj_sandoz)
Most b16a from japan are obd 0 and no obd conversion is needed to put it in you car..
Old Feb 11, 2003 | 03:01 PM
Neukin's Avatar
Default Re: b 16 question (crx616)
dont forget about the resistor box for the injectors if you run obd0
patwitahonda
Oct 10, 2009 09:36 AM
4dOoR-Ex
Jan 29, 2007 01:25 PM
RA122324
Jun 17, 2005 04:02 PM
ironchef25
29
Jan 27, 2004 06:22 AM
Norcalstoppy
Jul 9, 2002 01:40 AM
