KYB Super Gymkhana coilover struts???
I has seen someone posted some pics about buying these a while back, so i tried to use the search and had no luck.
the struts were coilover type (steel i believe)
does anyone know where i can get some info (in english) about these
i saw pics on some japanese website that had a "double adjustable" version that was all aluminum
heres the only pics i could find
steel bodied
aluminum bodied
i am especially interested in the aluminum type for my EG hatch
heres the website where they were found
http://www.cs-compe.co.jp/02shopping/kyb.htm
thanks
-scott
[Modified by scottg, 10:43 PM 2/8/2003]
steel bodied
aluminum bodied
thanks
-scott
Threaded steel body, monotube short stroke with 45mm valve diameter, 4-level adjustability (1 softest, 4 stiffest), weigh about 3kg each, can handle HIGH spring rates.
what about ease of accessibility for adjustment once installed and risk of galling?
As for the risk of galling, which part are you referring to?
So how much $ are the steel versions?
and how much $ are the aluminum versions?
are the steel dampers servicable? (obvoiusly the aluminum ones are)
where can they be obtained?
do the rear dampers come with helper springs like the pic, or are those seperate?
what about pillow mounts?
[Modified by scottg, 12:12 PM 2/9/2003]
the steel version (the one i got) is around $750.00, Wai said the aluminum version is about double the price.
I don't think mine is servicable....at least I can't see any possible part on the damper which can be open. The helper spring you see is optional and not include from the box, so as the pillow mount.
SuicideSlide
May 7, 2003 04:56 AM
