Rusted Flywheel!!!
Old Feb 8, 2003 | 06:09 PM
2muchPSI's Avatar
Default Rusted Flywheel!!!
Hey,
My engine has been out of my car on an engine stand for like 6 months, and the flywheel now has surface rust on it. Just a very thin coat. It was just resurfaced like 4,000 miles ago, so i dont want to do that again. How can I get this rust off. Should I just wet sand. Any imput would be much appreciated.
Old Feb 8, 2003 | 06:15 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Rusted Flywheel!!! (92tealvx)
Some coca cola and tin foil no lying it works for minor rust
Blaze
Old Feb 8, 2003 | 06:36 PM
escocrx's Avatar
almost the same instance as why is there rust on my brake rotors.
use it. and it'll rub off without messing anything up.
Old Feb 9, 2003 | 07:59 AM
2muchPSI's Avatar
Default Re: Rusted Flywheel!!! (Blaze45)
haha, so i should just pour coke on it? what do u do with the tin foil
Old Feb 9, 2003 | 08:09 AM
Just536's Avatar
Don't mess with it, just drive it. It will be cleaned off in less then time then you can say "coke & tin foil".
Old Feb 9, 2003 | 08:54 AM
2muchPSI's Avatar
Default Re: Rusted Flywheel!!! (Just536)
will the rust hurt the clutch at all?
Old Feb 9, 2003 | 11:37 AM
koco's Avatar
You can just sand it off with 400 grit sandpaper if it bothers you that much. Otherwise it'll wear off with use. If anyone thinks sandpaper is too harsh, think about what kind of conditions it normally works in.
I DO NOT recommend 400 grit sandpaper as a substitute for toilet paper.
crex23
Jul 10, 2009 05:57 PM
HondaIntegraR
May 22, 2005 01:03 PM
ViruSi
Dec 4, 2004 12:32 PM
See Are X
Jun 22, 2003 02:08 PM
lozersk8er
Nov 9, 2001 06:45 PM
