ATTN: all lightened flywheel owners...
how does your car start since haveing a lightened fly... my theory is that it is going start easier and faster (I will have a 7.5 lb fly) is there any truth to this?
thanks mike
thanks mike
Hey suggestions for flywheel brand for something about 8.5lbs and chromoly. Ive read a lot but am wondering about everyone's experiences with different ones.
i know that http://www.optauto.com has some flywheels, and sell ACT. thats where i got mine. good luck, just waiting for mine to get here now.
I doubt that it will have much effect. The biggest resistance to turning is the compression. Ever cranked a motor with the plugs out?
higher compresion=quicker starts? is that what your saying
exactly what b19coupe said. ever try to turn you motor when you do a valve adjustment with the spark plugs in, and with the spark plugs out, you feel a difference in the amount of force you gotta use to turn the motor over. so without the plugs, the motor spins quicker and easier.
i would figure on a boosted car you would spool faster since youy would rev quicker, so why do people advise against light fly's for boost?
I did not notice any difference in starting. I will say that I went with a 12lbs flywheel and it is not light enough. If I had to do it over I would probably get something in the 9lbs range.
I have the comptech chromoly 8.75lb wheel. Starting time of the car has not changed one bit. However throttle response is greatly improved. It just a blip of the throttle to rev match...very nice!
The advantages are that your car will rev quicker. There's a graph around here, the only one I've seen, it shows a clear HP gain w/ a lighter fly. There are no disadvantages IMO. Make the engine move less mass and it has more power and revs faster.
how much do those run for? i was thinking of getting the comptech flywheel. U said chromoly right? how much of a differance do you feel, accel/decel?
