Bouncy suspension (Tien S tech on stocks)
Old Feb 8, 2003 | 04:30 PM
oryanh's Avatar
Default Bouncy suspension (Tien S tech on stocks)
I've found my S tech mediums are a bit bouncy on the stock shocks...
Does this usually mean the shocks are not well matched with the spring rate?
Anyone here with the same setup?
If so, can any compare to a good shock replacement?
thanks!
[Modified by oryanh, 7:31 PM 2/8/2003]
Old Feb 8, 2003 | 04:41 PM
Flux's Avatar
Default Re: Bouncy suspension (oryanh)
yes, your shocks are unable to dampen the springs properly... I don't think you can go wrong with KONI or GAB. I am running TODA FIGHTEX coilovers, so I am no expert on matching dampers to springs, others will have more suggestions...
Old Feb 8, 2003 | 04:46 PM
oryanh's Avatar
Default Re: Bouncy suspension (Flux)
Must be nice...
Old Feb 8, 2003 | 05:02 PM
Denny's Avatar
I am using tein s-tech springs. Mine arent bouncy at all. People usally ask me what coilovers im useing
Old Feb 8, 2003 | 05:16 PM
oryanh's Avatar
Default Re: Bouncy suspension (TypeR882)
It must be my perception of "bouncy."
Old Feb 8, 2003 | 07:23 PM
d8168055's Avatar
maybe u didnt cut ur bumpstops enough... now much of a drop is it?
Old Feb 8, 2003 | 08:10 PM
disordeR's Avatar
Default Re: Bouncy suspension (d8168055)
generally yes, unmatched springs can cause a very bumpy ride.
right now, i'm loving my coil overs. they're awesome.
TigerLy
Jun 17, 2008 01:07 AM
dom5372
Suspension & Brakes
Nov 16, 2005 11:44 AM
HYPEBEAST!
Suspension & Brakes
Apr 10, 2005 12:34 PM
DeL SLo
Apr 15, 2004 02:08 AM
501 Lude
Jun 20, 2003 05:07 AM
