seat belts - is this bad?
Old Feb 8, 2003 | 03:23 PM
Chris y0!'s Avatar
Default seat belts - is this bad?
not my car-
i know that having those belts + no cage is bad, but is having the belts mounted that way bad? i always thought if you mounted the backs of the belts that low, your back would be compressed in an accident. tia.
Old Feb 8, 2003 | 03:27 PM
nsxmatt's Avatar
Default Re: seat belts - is this bad? (Spoon Hybrid)
They should mount on the cage..... wait no cage. Oh well he's gone either way
Old Feb 8, 2003 | 03:43 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You are correct, the shoulder straps should pass back behind the seats at as close to horizontal as possible (parallel to the ground). If you have to run them slightly lower that's alright, but I wouldn't go more than 15-20 degrees below horizontal, 30 deg. MAX.
spoonek4's Avatar
Bride seats TAKATA harness ...probably not a right way on the harness but not 100% sure.
Old Feb 8, 2003 | 03:49 PM
KOALA YUMMIES's Avatar
Default Re: seat belts - is this bad? (spoonek4)
"Those Takata harnesses will own him without a roll bar"
Yeah they should be mounted to a roll bar, however I have seen certain ways to safely mount them w/o one, however on the street thats just dumb, even if it is "Takata".
Old Feb 8, 2003 | 03:50 PM
Hooch'n's Avatar
No, this is not correct. However, rules in Japan arn't like US track standards. Example: Spoon DC2 isn't prepared as well as the Grand Am or Speedvision DC2's. Roll cages are different, ex. So, no this isn't the best way to mount 4 point harness. Better way would be with a J's Bar or Roll Cage.
Old Feb 8, 2003 | 04:41 PM
lonefuzzy79's Avatar
My understanding is that the way you have them mounted they will break your shoulders if you are impacted. They need to be mounted at the same height as your shoulder. There are harness bars out there for like $90 that will fix you up.
Old Feb 8, 2003 | 04:47 PM
96 SOHC VTEC's Avatar
That is not correct, and it is stupid to have harnesses without a rollcage, especially on the track.
Old Feb 8, 2003 | 05:04 PM
EK MONEY's Avatar
Default Re: seat belts - is this bad? (96 SOHC VTEC)
needs a harness bar...
mathissi
Honda S2000
Feb 7, 2010 07:28 PM
trevorjohn88ef
Jul 19, 2008 04:09 PM
Gant
34
Jul 20, 2006 09:32 AM
NotSoSlimShady
May 7, 2005 12:00 PM
MintyDip
36
Jul 13, 2002 11:48 AM
