?? about OEM keyless entry (kinda long)
i have a 96 ex coupe with keyless entry...about 2 months ago my battery in my remote went dead...i replaced it...then i had to reprogram the remote with the radio...the remote work for about 2-3 weeks..now for the past month the keyless entry wont work...ive bought 2 new remote and tried to reprogram these 2..when i program the remotes the door are getting the singal cuz they lock..then i take the key out of the ingnition and try to lock or unlock the doors and nothing happens..BTW i have a stock radio with OEM cd changer...i do have an SI deck laying around that i will prolly be putting in if i cant figure this out...
my ?? are:
1. could my problem be with my stock head unit??
2. could it be that i have gotten bad remotes??
TIA
late
[Modified by synergy010, 5:46 PM 2/9/2003]
my ?? are:
TIA
late
my ?? are:
TIA
late
my ?? are:
TIA
late
sounds to me like a keyless entry problem.. but not sure.. its is possible to add another radio to your car have the keyless entry still work.. is done all the times and it will work w/ your SI deck w/ no problems.. just get a honda t-harness from any audio shop and hid the stock unit behind the dash.. keyless will still work and you willl have an SI deck now also
[Modified by txsynergy, 7:59 AM 2/11/2003]
well i know that i can put in a SI deck with problem..but do u think i have a problem with the head unit (were the brain is located)..thank for ur help..
You need to take off Synergy from your s/n becuase you dont belong with us. It's pretty fucked up how you had BeastB18Alpha@aol.com or whoever the moderator is that you know **** around with my title, my sig and my location. We aren't about that. You're a lil B*tch!!
[Modified by TEaMxSyNeRgYx001, 4:24 AM 2/13/2003]
Ethan Cole
Mar 13, 2014 08:47 PM
