Update on the B16A that will never run
Old Feb 8, 2003 | 02:01 PM
APEX i GSR's Avatar
Default Update on the B16A that will never run
some of you might remember me
i was the one who was putting a B16A1 in a 91 STD
here is a previous post to refresh your memory
https://honda-tech.com/zerothread?id=363400
well i messed with it today & it finally starts to run
the new problem is now it won't idle past 2000 rpm & it takes forever to get that high
it is still reading a code 4 Crank angle sensor
i have checked the wires numerous times
when it does tun i can see some fuel coming out of the open header
Does anybody have any idea of what it could be now?
will this car ever run?
Old Feb 8, 2003 | 03:07 PM
biggdogg's Avatar
Default Re: Update on the B16A that will never run (APEX i GSR)
send the harness back and get a place racing harness. i used the place full harness conversion when i put my 1st b18a in and when i went vtec i used their sub harness . everthing runs great . maybe your reading the ecu pinouts backwards. flip them over and star over from there also you have a std not a dx . the wires at the distributor are different . i`ll try to scan the wiring diagram and send it to you . e-mail me at biggdogg187@comcast.net
[Modified by biggdogg, 7:09 PM 2/8/2003]
Old Feb 8, 2003 | 04:23 PM
PhatOptimo's Avatar
Hows the timing?
Old Feb 8, 2003 | 05:40 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Update on the B16A that will never run (Phat_Optimo)
Look at this months Honda Tunning. They have the MPFI swap and they have the VTEC wiring for the 88-91 CRX Civics.
Blaze
Old Feb 9, 2003 | 03:26 PM
APEX i GSR's Avatar
Default Re: Update on the B16A that will never run (Blaze45)
does anybody else have any other suggestions
i was thinking the same thing about the wiring harness
i was actually considering buying a new Civic wiring harness from the ECU to the engine already pinned
the thing just won't idle but tit is smokling when it finally does run
but when y ou increase the rpms it will not go over 2000 rpms
i think my next step might be to pull the engine & part out the car
Old Feb 10, 2003 | 03:03 PM
APEX i GSR's Avatar
anybody?
Old Feb 10, 2003 | 05:55 PM
APEX i GSR's Avatar
ttt
Old Feb 10, 2003 | 08:34 PM
PhatOptimo's Avatar
code 4 is distributor related. Right?
Old Feb 10, 2003 | 08:40 PM
FR-MOB: ThE bEe GuY's Avatar
Yep, the C.A.S. is inside the distributor. I had a code 4 on my A6 when my Distributor bearings went out, replaced the Dist. and that fixed the code also.
[Modified by ThE bEe GuY, 5:41 AM 2/11/2003]
Old Feb 10, 2003 | 08:57 PM
-16V-'s Avatar
Default Re: Update on the B16A that will never run (ThE bEe GuY)
Get a helms if you dont have one, And dont give up!!!!
turboef90
Aug 25, 2012 07:22 PM
hb90racer
Feb 1, 2005 08:59 PM
rexheadb16a
May 30, 2003 03:10 PM
5thGhB
Mar 17, 2003 03:18 PM
