P72 ECU wiring question
My ECU is an OBDI P72 from a JDM integra SiVTEC, i just picked up a new last generation Apexi Rev speed meter and was going to fit it today, except i cant figure out the wiring on my ECU, it doesnt match up with the picture in the apexi manula that i downloaded, there are only 5 wires i need to tap into as i already have a vtec controller which removed the speed limiter. So can someone please help me figure out which are the following wires on my ECU:
Ignition power
Constant Power
RPM signal
Ground (found this one)
VSS (found this one)
If someone has a JDM P72 OBD1 could you please either post a pic of the corresponding wires on the ECU or tell me which wire (eg location) i need to tap into.
Thanks in advance
Ignition power
Constant Power
RPM signal
Thanks in advance
Hey, slightly off topic, but what happened to ya on Yesterday, thought you were coming to the Jspeed rolling road day??
I was supposed to get that Strut brace off you??
Check out the report on the day, tis linked in the Forum, some interesting results.
Bren
Bren
