which exhaust to get..hmmm
Old Feb 8, 2003 | 11:51 AM
gumbybum's Avatar
Default which exhaust to get..hmmm
i dont what exhaust i should get im thinkin tanabe or 5zigen but i just dont know.. it is really time for exhaust, and i plan on goin turbo-so give me some ideas if you could. oh yah im also not made of money...you guys get the point, thanx a lot
Old Feb 8, 2003 | 12:15 PM
acatak's Avatar
Default Re: which exhaust to get..hmmm (gumbybum)
Well if your going turbo, your going to want to get a 3inch exhaust. I kno Thermal makes a great 3inch exhaust. It will probably cost you around $450-500 new.
Old Feb 8, 2003 | 12:53 PM
JapSpec954's Avatar
Default Re: which exhaust to get..hmmm (acatak)
is a 3 inch really necessary? it wouldnt b wise two get like a 2 1/4 or 2 1/2 inch?
Old Feb 8, 2003 | 08:30 PM
tub_sephiroth's Avatar
Default Re: which exhaust to get..hmmm (JapSpec954)
2.25 is too small. Try 2.5
Old Feb 8, 2003 | 09:05 PM
JapSpec954's Avatar
Default Re: which exhaust to get..hmmm (tub_sephiroth)
so wat would b a good exhaust to get besides thermal or greddy PE? would a greddy evo b good?
Old Feb 8, 2003 | 09:06 PM
au-gsr's Avatar
man i tell everyone the smae thing so here ya go a quote from an earlier thread that is my response. pay careful attention and remeber its not who makes the catback exhaust, it's what will best suit your setup/future setup. no reaseon to waste money on parts like this. sorry i'll stooop ramblin and tell ya. . .
quote-
ok i have done a lot of personal research on this subject for a while. it really comes down to what horsepower range is your goal. if youare looking to put out 200hp at the wheels on a b18c1, or any engine for that matter,you will need an exhaust with at least a 2 3/8" diameter. the most you could put out with this diameter exhaust would be around 230-250. the 2.25" diameter will cap you off around the 180-190 range. 2.5" will cap you off around 290-300. so i hope that helps you on making a decision. although price sound quality and customer service do come into play as well. personally, i would get a magna flow muffler withcustom 2.5" tubing with a resonator. this will save you a lot of money and will cost around 200-250 depending on how much the shop you go to charges. the magna flow will sound just like the comptech exhaust especially if you get a straight through design on the muffler.
Old Feb 8, 2003 | 09:07 PM
StyleTEG's Avatar
2.5" would be ok for lower boost, 3" would be optimal if you plan on running more than 8-9psi.
threatcon13's Avatar
New User
3" is good for turbo. the one that i kno of off the top of my head is a thermal r&d 3".
Old Feb 8, 2003 | 09:08 PM
New User
its very necessary.
Old Feb 8, 2003 | 09:09 PM
au-gsr's Avatar
Default Re: which exhaust to get..hmmm (au-gsr)
and if you are going turbo you will want at least a 2.5-3" exhaust. this is allh depending on what altitude you live at, the boost you wanna run and the goals you want. 3" can support 300-400 hp no problem but you have to make sure you get it all right otherwise you'll sound like a fart can and your engine will bog at certain rpm's-the low ones-till the turbo spools up.
Old Feb 8, 2003 | 09:16 PM
StyleTEG's Avatar
Keep in mind that a boosted engine is going to create more exhaust gases at any given rpm than an all motor creating equal HP.
Originally Posted by Neouser
Now, once you boost a motor, you're increasing the peak cylinder pressure, as well as the duration of peak cylinder pressure. Why? Because of the sheer size of the charge and the massive flame front. A boosted motor will, in fact, produce higher quantities of exhaust gasses, regardless of rpm. What we need here is flow. Velocity is still important (Which is why I recommened a 2.5" exhaust instead of a 3") in order to help scavenge the pulses, but now, instead of being tuned to scavenge a fixed amount of gasses at a higher speed, you need the exhaust system to scavenge a larger quantity of gasses at every speed. See where I'm coming from? A boosted motor produces high power through a larger charge, not a more frequent one.
http://www.team-integra.net/forum/di...PagePosition=2
This was a discussion on exhaust and N2O, but it has alot of good FI + exhaust info as well. Worth the read.
Old Feb 8, 2003 | 09:21 PM
JapSpec954's Avatar
so wat i should do is getta muffler n get custom pipin made at a local muffler shop?
Old Feb 8, 2003 | 09:24 PM
New User
quote-
thats all good for all motor but this is for a turbo applicatoin...
Old Feb 8, 2003 | 09:25 PM
New User
yes..or u can get the thermal.
Old Feb 8, 2003 | 09:28 PM
JapSpec954's Avatar
Default Re: which exhaust to get..hmmm (Threatcon13)
quote
so wat should u do fora turbo application ?
Old Feb 8, 2003 | 09:32 PM
New User
look at his next post. i would recommend going 3", especially if you plan on turning up the boost anytime down the line.
CivicRyDa
Honda Civic (2001 - 2005)
Dec 22, 2010 07:02 PM
sil04ver
Nov 16, 2007 05:13 PM
JICsube
Jul 3, 2002 07:14 AM
