I needed to use a P72 timing belt on my stock LS?
Old Feb 8, 2003 | 10:55 AM
HybriDNA's Avatar
Default I needed to use a P72 timing belt on my stock LS?
Well im building up a stock LS motor. I have rebuilt everything on it with oem parts. The block is a 93 b18a1 and i have a 00 b20z head on the block. Well when i bought a LS timing belt it didn't fit so i bought a P72 timing belt (b18c1) which has one more tooth then the LS timing belt and it fit perfect! I bought the block from someone so maybe they put a B16 or B18c waterpump upgraded on it, since i didn't change the waterpump because it was new im not sure if its a LS water pump or Vtec water pump.
Heres my question:
On the waterpump that i have it says 22T... Can anyone tell me how many teeth the LS water pump has?
Old Feb 8, 2003 | 12:28 PM
b19coupe's Avatar
Default Re: I needed to use a P72 timing belt on my stock LS? (HybriDNA)
https://honda-tech.com/zerothread?id=240352
JTTeG_X
Jul 17, 2013 10:50 AM
B18B1-Crx
Jun 18, 2011 07:59 PM
jdmCivic925
Jan 25, 2006 08:37 PM
B18 CYA
May 11, 2005 03:11 PM
