whats the advantage??
Old Feb 8, 2003 | 10:37 AM
LillDragun's Avatar
Default whats the advantage??
what would be the advantage in changing to ITR rear LCA??
Old Feb 8, 2003 | 10:49 AM
LillDragun's Avatar
Default Re: whats the advantage?? (LillDragun)
no one knows?
Old Feb 8, 2003 | 11:00 AM
ZygSpeed's Avatar
The only reason to do this would be if you were changing to an ITR suspension/rear shocks (possibly also if you went with a 5 lug conversion).
Old Feb 8, 2003 | 11:02 AM
vactor's Avatar
u can use ITR/CRX specific shocks.
LillDragun's Avatar
Default Re: whats the advantage?? (zygspeed)
would it be worth it if i could get rear koni yellow shocks for 160 shipped......but they are the internally adjusting ones (you have to turn the body of the shocks to adjust it)
Old Feb 8, 2003 | 11:09 AM
ZygSpeed's Avatar
Why don't you just get the right Koni shocks for your car?
Instead of having to change the LCA's ...
Old Feb 8, 2003 | 11:19 AM
LillDragun's Avatar
it seems a hella cheaper this way.....and i have noticed that alot of people have changed they're LCAs to the ITR ones. would it be safe? i mean i don't wanna be driving one day and the rear suspension just falls apart on me
Old Feb 8, 2003 | 11:49 AM
LillDragun's Avatar
eh?
Old Feb 8, 2003 | 11:53 AM
ZygSpeed's Avatar
Nobody likes answering essentially the same question over and over again!
Do what you want.
Old Feb 8, 2003 | 12:05 PM
Christian's Avatar
Just to be redundant and further clarify what Ed just stated. There is absolutely no reason or benifit for you to change to the ITR LCA's. They do the same function and one isn't any better than the other
The only reason you would, was if you are buying a suspension that is only available for a CRX or Type R. Based on your choice, that shouldn't be an issue.
So save yourself $75 keep your LCA
aw614
Suspension & Brakes
May 12, 2013 01:52 PM
Reelizmpro
23
Oct 8, 2004 07:41 PM
Nighthawk GS-R
Sep 3, 2001 02:40 PM
