Which engine to go with?
Old Feb 7, 2003 | 06:57 PM
Aquafina's Avatar
Default Which engine to go with?
I might be getting a 91 CRX with an engine that is about to blow......so......
which engine would I be better off swapping into it?
B18B from a DA integra
-or-
B16A from EK Civic
Old Feb 7, 2003 | 07:04 PM
CHRIS 1.8's Avatar
Default Re: Which engine to go with? (SuperStreetRX7)
What are your goals?
Old Feb 7, 2003 | 07:12 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Which engine to go with? (CHRIS 1.8)
whats your budget?
Blaze
Old Feb 7, 2003 | 07:49 PM
Aquafina's Avatar
Default Re: Which engine to go with? (Blaze45)
My budget for the engine and tranny is around 2,000. I would like to get it to run at least 13's.
Old Feb 7, 2003 | 08:00 PM
importfan85's Avatar
It'd probably be cheaper to get the b18 out of an old integra. Plus, the wiring won't be as much of a pain (I think).
Old Feb 7, 2003 | 08:18 PM
slowman's Avatar
I took way too long
Default Re: Which engine to go with? (importfan85)
the b18 and boost it.
Old Feb 7, 2003 | 10:10 PM
90RioGS's Avatar
Just to clarify, the DA integras had a B18A (90-91 had OBD0 130Hp; 92-93 had OBD1 140Hp).
The 3rd gens had the B18B (142Hp)
Old Feb 7, 2003 | 11:09 PM
HandCommand's Avatar
Default Re: Which engine to go with? (90RioGS)
I was just about to say that until I scrolled to the bottom and saw your post
Old Feb 7, 2003 | 11:33 PM
SkylineGTR's Avatar
Default Re: Which engine to go with? (HandCommand)
You really can't go wrong with either. You'll probably experience about the same time with the B16 being a bit faster with the basic bolt ons. If you get a B16 and get i/h/e and some good cams and tune them properly along with some weight reduction, 13's is a very realistic goal. That is not too much of a big budget.
Old Feb 8, 2003 | 12:26 AM
Brandon Chun's Avatar
Default Re: Which engine to go with? (SkylineGTR)
Go with a B18A you might want to budget a little more money than 2000, never know what can happen with a swap
Old Feb 8, 2003 | 12:57 AM
usdm_ED7's Avatar
Default Re: Which engine to go with? (Brandon Chun)
i dont htink you can use $2000 and 13s in the same sentence...well maybe u can try SOHC nos...dish out more and go b18Boost...go0d luck
fastrxu
25
Jan 17, 2010 12:38 PM
02_IT-S
266
Aug 22, 2009 09:57 PM
89bluehatch
Feb 25, 2007 11:20 AM
Fired Honda
Jul 27, 2003 10:31 PM
Crash52722
49
Jun 24, 2003 01:10 AM
