rear disc conversion question.
Old Feb 7, 2003 | 02:16 PM
soslow93's Avatar
Default rear disc conversion question.
will 95 rear discs off a del sol fit my 93 4dr? i know the tegra 94+ will bolt on,i was wondering if the sol's would do the same?
any thoughts?
Old Feb 7, 2003 | 02:58 PM
soslow93's Avatar
Default Re: rear disc conversion question. (soslow93)
anyone help.
Old Feb 7, 2003 | 04:11 PM
eg6sir-s's Avatar
yes, it will fit...dont forget to get an integra master cylinder and you may utilize your stock proportioning valve...just make sure to bleed your brakes.
Old Feb 7, 2003 | 05:17 PM
Run Hatch's Avatar
Default Re: rear disc conversion question. (eg6si)
good luck
Old Feb 7, 2003 | 06:12 PM
soslow93's Avatar
stock poportioning valve?i figured id have to get an integra master cylinder.but not sure what you mean by stock pop.valve?
Old Feb 7, 2003 | 06:14 PM
soslow93's Avatar
i was wanting to just unbolt upper and lower control with calipers and discs intact and replace on the 93.should this be a problem?
Old Feb 7, 2003 | 08:16 PM
conesmasher's Avatar
Newcome you gotta do a porportioning valve, you can get them from Baer if you wanna, but their is also a stock one that regulates how much brake power to distribute to front and rear braking systems.
Old Feb 7, 2003 | 10:59 PM
Sasebonian's Avatar
The e-brake cables will be a bit short. (Unless you are ghetto at let it stretch instead of properly mounting them) I did my disc conversion with del sol's, and I had to get the correct e-brake lines.
Old Feb 8, 2003 | 12:00 PM
soslow93's Avatar
which ebrake cable to use?
Old Feb 9, 2003 | 10:29 AM
Sasebonian's Avatar
You can use the e-brake cables from a civic or an integra, but not a del sol. (For proper oem fitment)
Old Feb 9, 2003 | 03:14 PM
f0rum's Avatar
The brake lines are also different, need some from a civic/integra/del sol w/rear disc as well.
Old Feb 9, 2003 | 03:54 PM
piscorpio's Avatar
Default Re: rear disc conversion question. (Sasebonian)
Was ghetto with his brake swap.
Good luck with the install. I don't know about Del Sol's, but on my EK the e-brake cables were kind of a bitch to route into the cabin (not because they were Integra cables). If the Del Sol is anywhere similar to the EK, you may want to drop down a section of your exhaust to make accessing the e-brake brackets a little easier. Again, this pertains to the EK, but maybe someone can let you know if the Sol has the same issue.
Old Feb 11, 2003 | 08:35 PM
Default Re: rear disc conversion question. (piscorpio)
bump, for my boy, he needs more help someone give him some tips
Old Feb 11, 2003 | 08:39 PM
piscorpio's Avatar
Default Re: rear disc conversion question. (snoballgsr)
If he has never done this before, set aside plenty of time to get it done. You just never know when something will go wrong, a bolt will be really stubborn, etc. Make sure he is not doing the install, and needs the car up and running within a few hours.
Don't forget to bleed the brakes, and adjust the e-brake.
Old Feb 12, 2003 | 06:42 PM
thanks guys any more tips for em
wstmsol
Suspension & Brakes
Dec 19, 2011 08:43 PM
B00stedH22A
10
Nov 18, 2010 06:25 AM
asianman139608
Oct 26, 2009 07:21 AM
dccndc1
Mar 27, 2009 12:10 AM
Bulli Kid
Jul 9, 2007 07:03 AM
