rear disc conversion question.
will 95 rear discs off a del sol fit my 93 4dr? i know the tegra 94+ will bolt on,i was wondering if the sol's would do the same?
any thoughts?
any thoughts?
Re: rear disc conversion question. (soslow93)
yes, it will fit...dont forget to get an integra master cylinder and you may utilize your stock proportioning valve...just make sure to bleed your brakes.
Re: rear disc conversion question. (eg6si)
stock poportioning valve?i figured id have to get an integra master cylinder.but not sure what you mean by stock pop.valve?
i was wanting to just unbolt upper and lower control with calipers and discs intact and replace on the 93.should this be a problem?
Newcome you gotta do a porportioning valve, you can get them from Baer if you wanna, but their is also a stock one that regulates how much brake power to distribute to front and rear braking systems.
The e-brake cables will be a bit short. (Unless you are ghetto at let it stretch instead of properly mounting them) I did my disc conversion with del sol's, and I had to get the correct e-brake lines.
Re: rear disc conversion question. (Sasebonian)
Good luck with the install. I don't know about Del Sol's, but on my EK the e-brake cables were kind of a bitch to route into the cabin (not because they were Integra cables). If the Del Sol is anywhere similar to the EK, you may want to drop down a section of your exhaust to make accessing the e-brake brackets a little easier. Again, this pertains to the EK, but maybe someone can let you know if the Sol has the same issue.
Re: rear disc conversion question. (snoballgsr)
bump, for my boy, he needs more help someone give him some tips
Don't forget to bleed the brakes, and adjust the e-brake.
Re: rear disc conversion question. (piscorpio)
If he has never done this before, set aside plenty of time to get it done. You just never know when something will go wrong, a bolt will be really stubborn, etc. Make sure he is not doing the install, and needs the car up and running within a few hours.
B00stedH22A
10
11-18-2010 06:25 AM
asianman139608
10-26-2009 07:21 AM
