Torque specs for LCA's? 99 Civic
Old Feb 7, 2003 | 12:27 PM
KURRRRWA
Guest
Posts: n/a
Default Torque specs for LCA's? 99 Civic
Hi, I am about to pick up a new LCA because my old one was bent to hell...
I'm picking up an OEM unit.
What are the torque specs on the three bolts? What dod you guys do when you installed all your fancy LCA's?
Thanks a million
Old Feb 7, 2003 | 01:44 PM
yaya's Avatar
Default Re: Torque specs for LCA's? 99 Civic (KURRRRWA)
just make it tight
Old Feb 7, 2003 | 01:53 PM
splitime's Avatar
Default Re: Torque specs for LCA's? 99 Civic (cancan)
And make sure to use alot of antiseize, it'll make you happy if they ever need to come off again.
Old Feb 7, 2003 | 02:01 PM
poo flinger
Guest
Posts: n/a
Default Re: Torque specs for LCA's? 99 Civic (splitime)
Happy? Why would he be happy if they come off?
Old Feb 7, 2003 | 02:39 PM
splitime's Avatar
Default Re: Torque specs for LCA's? 99 Civic (I can't believe this ****)
Your're kidding right? its a preventitive measure, those bolts are known to seize up alot. If he doesnt want to have a siezed bolt later antisieze will prevent this. Its not a lube, just a seizing prevention product.
Old Feb 7, 2003 | 04:30 PM
KURRRRWA
Guest
Posts: n/a
Thanks, but do you know the specs on the nuts? Or just as tight as I can?
Old Feb 7, 2003 | 04:36 PM
fowler!'s Avatar
As tight as you can is fine.
My LCA never fell off.
Old Feb 10, 2003 | 06:12 PM
KURRRRWA
Guest
Posts: n/a
OK I did 65 pounds..... it seems that the LCA i didn't mess wit was at about that too...
Thanks guys.
Old Feb 11, 2003 | 06:03 AM
kommon_sense's Avatar
I want to say that specs are in the 44-54ft-lb ballpark. I don't have my manual in front me, but you went to 65ft-lb, so it shouldn't be goign anywhere
Old Feb 11, 2003 | 07:21 AM
EK MONEY's Avatar
hes in cali. **** dont rain there! No need for locktight! just crank that **** on!
Old Feb 11, 2003 | 07:28 AM
FifthGearOnline's Avatar
Default Re: Torque specs for LCA's? 99 Civic (Peagreenhatch)
according to the helms manual for all 96-00 civics
the flange bolt for the Rear Lower Control Arm is to be tighened to 40 foot pounds
Old Feb 11, 2003 | 07:30 AM
ImportechPerformance's Avatar
Default Re: Torque specs for LCA's? 99 Civic (FifthGearOnline)
just torque em till the impact gun says no more loves his impact gun
Old Feb 11, 2003 | 11:30 AM
KURRRRWA
Guest
Posts: n/a
O ****! Do you think anything will happen now that it's at 65 pounds, or am I safe?
And, no, my car does not ever see rain.
Thanks guys.
Old Feb 11, 2003 | 11:58 AM
I would probably retorque it to spec.
Old Feb 11, 2003 | 12:53 PM
SpoonEK2's Avatar
I concur. The rear ones are 40 foot pounds. The front one's are 78 foot pounds i believe.
Old Feb 11, 2003 | 01:05 PM
splitime's Avatar
Um, i didnt say locktite, and i hope no one ever uses that stuff on an LCA bolt, they seize enough on their own. Also does no one know how antisieze works? Good or bad weather, that metal will form deposits just from being in the open air, not to mention rain and all the goodness. Antiseize prevents the bushing metal piece/bolt/welded nut from becoming one pain in the **** unit. sheez
Hunter
Feb 17, 2011 06:31 PM
MindBomber
Suspension & Brakes
20
Sep 13, 2010 10:07 PM
slomofo
Honda Civic (2001 - 2005)
Aug 6, 2010 06:11 PM
Madracer1
10
Dec 19, 2002 01:49 PM
May 27, 2002 06:09 AM
