About to Start on My Timing Belts...Last Minute Tips?
Old Feb 7, 2003 | 11:43 AM
hankd's Avatar
Default About to Start on My Timing Belts...Last Minute Tips?
I've got the Helmes manual...but does anybody have any advice? Maybe some common mistakes that people make, or I could make? I just don't want to mess this up because of something stupid that I'm not aware of...
What are my chances of getting the crank bolt broken loose without an impact wrench??
Thanks in advance...
Old Feb 7, 2003 | 11:58 AM
YumVTEC's Avatar
Default Re: About to Start on My Timing Belts...Last Minute Tips? (hankd)
crank pully bolt sucks to get off without an impact and air. good luck on that. i'm pretty sure you have only one timing belt, not belts too...
Old Feb 7, 2003 | 12:25 PM
jweller's Avatar
https://honda-tech.com/zerothread?id=328470
in the end, I paid the guy at the corner garage to break it loose...
most common mistake is putting the belt back on a tooth off. just put any extra slack in the belt on the water pump side(before you set the tensioner) and it should come out right. take your time and double check it.
Old Feb 7, 2003 | 12:42 PM
niedejb's Avatar
Default Re: About to Start on My Timing Belts...Last Minute Tips? (jweller)
Balancer shaft seal retainer.
Hippie got me the part number:
06923-POA-306
Old Feb 7, 2003 | 01:54 PM
hankd's Avatar
Default Re: About to Start on My Timing Belts...Last Minute Tips? (YumVTEC)
LOL...yea, just one timing belt I'm doing the tensioner belt too...
Good thread Jweller...I thought about doing that, but I guess I'll try it first and see if it will break loose...
niedejb...I ordered 2 oil seals...not sure if they're the same as the one. I got #30 in this pic:
http://www.hondaautomotiveparts.com/...13SM40_A03.gif
and #31 in this pic:
http://www.hondaautomotiveparts.com/...13SM40_A05.gif
also timing belt, tensioner belt, PS belt, alt belt, water pump, and 2 springs (#18 and #12 in the first pic above)...
Thanks guys...
Old Feb 7, 2003 | 02:15 PM
niedejb's Avatar
The retainer holds the #31 in .....notorious recall.
Old Feb 7, 2003 | 04:49 PM
tilt's Avatar
Default Re: About to Start on My Timing Belts...Last Minute Tips? (niedejb)
what is a tensioner belt??
Old Feb 7, 2003 | 05:12 PM
hankd's Avatar
I don't see the retainer on the parts list on HondaAutomotiveParts.com. I'll try to figure out what you're talking about when I get there. I basically bought everything that the guy at HondaAutomotiveParts.com recommended...
Tilt...I listed the tensioner belt
So far so good. I've got the cruise control, PS pump, alternator, motor mount, dipstick, valve cover, and upper cover off. Taking a break right now...I'm in no hurry...don't wanna screw this up
Old Feb 7, 2003 | 07:26 PM
Conechaser's Avatar
'90-'97 Honda Accords have 2 Timing belts.
Accord 90 - 93 All 2 belts - $61.87
Accord 94 - 97 EX 2 belts - $70.03
From http://www.manchesterhonda.com
Old Feb 8, 2003 | 07:11 PM
Hippie's Avatar
Drive to you nearest dealer if you have to but DO NOT put it back together without that "recall retainer" !!!!!!
I had it and didn't put it in mine because the directions are printed so small old farts like me can't even see 'em much less read 'em and I couldn't tell that part of it went outside the timing cover so I assumed they gave me the wrong one and since my seal looked good I didn't need it. W-R-O-N-G!!!!!!! The seal popped out a few weeks later on the way to work, I came VERY close to losin' my motor. As it was I had to go through the whole process again plus my new belts were covered in oil, and my driveway and my parking spot at work and the whole underside and back end of my car and the car that was behind me when it blew. That guy still gives me dirty looks when he sees me.
Old Feb 9, 2003 | 06:50 AM
hankd's Avatar
Default Re: About to Start on My Timing Belts...Last Minute Tips? (Hippie)
Hippie,
I want to do this right and I'm in no hurry since I can drive my TA for as long as the Honda is down, so I'll pick that part up tomorrow.
Which one is it on this picture:
What's the Honda part number??
I didn't touch the car yesterday. I've got a compressor and inpact now, so I'm gonna try the crank bolt today.
Thanks guys,
Hank
Old Feb 9, 2003 | 07:24 AM
niedejb's Avatar
Its not in the pic. I posted the part number above.....
06923-POA-306
Old Feb 9, 2003 | 10:43 AM
hankd's Avatar
Thanks man...I didn't know what you were talking abuot when you said "Hippie got me the part number" since he hadn't posted in the thread yet
Thanks!
Old Feb 9, 2003 | 01:52 PM
niedejb's Avatar
Snapped a pic of mine today
Hippie...turns out the current engine had one on it and I just reused it for the built one (so I didnt need the part number afterall...sorry).
Old Feb 9, 2003 | 03:23 PM
hankd's Avatar
Thanks man...
I can't do much about it until I can get this crank bolt though...
Sears impact wrench with 100 psi pushing it wouldn't break it loose...so I went down to Home Depot and picked up a 6 ft cheater...
Me
"Guaranteed Forever" huh?
I was afraid of that happening...I thought that the bolt had broken loose, but soon realized it hadn't. I'll pickup a heavy duty breaker bar tomorrow and give it another shot then...
[Modified by hankd, 4:21 PM 2/12/2003]
Old Feb 9, 2003 | 04:23 PM
SOHCMAN's Avatar
Craftsman right? Just take it in and they'll give you a new one free of charge. no big deal, but ya, fro that kind of torque you will need a nice beefy breaker with that 6ft cheater. good luck on the change!
sohc
Old Feb 9, 2003 | 07:03 PM
jweller's Avatar
Default Re: About to Start on My Timing Belts...Last Minute Tips? (SOHCMAN)
3/4in drive is your friend
Old Feb 9, 2003 | 07:36 PM
hankd's Avatar
Actually, Husky...supposed to be lifetime too though...
jweller...with anything longer than what I had with my ratchet and short socket, I won't be able to get the cheater up next to the fenderwell...it was already scraping as is. I might have to try a 3/8 breaker...I think 1/2 with my 1/2" 19 mm socket is going to be too long...
Old Feb 10, 2003 | 04:35 AM
jweller's Avatar
with a 6ft cheater, you're gonna break 3/8 ratchets like it's going out of style even snap-ons
maybe try slipping the cheater over a box wrench.
FWIW - you've got the exact same problem I had. barely any room to get the cheater bar in from the top. and the car isn't high enough off the ground to get any leverage from below.
Old Feb 10, 2003 | 05:21 AM
hankd's Avatar
Yea, you're probably right. I'm going to take a look at a 1/2 breaker and if it bends past 90* it might work...
I'm going to look around and see if anything else looks like it will work too...
Gonna try a different impact tonight also...
Old Feb 10, 2003 | 10:25 AM
hankd's Avatar
I have to ask again, just for the hell of it...
This bolt is NOT a reverse thread, correct? Nothing has indicated that it is...whether on here or in the Helmes manual...
I've got a new stash of tools to try tonight :D
Old Feb 10, 2003 | 11:16 AM
niedejb's Avatar
Nope. Took mine off this Sat. The engine was out of the car though.
Old Feb 10, 2003 | 07:29 PM
hankd's Avatar
I just had to make sure again...that's the first thing everybody has asked me...
Well, after 3 hrs tonight, still no luck. I tried 2 more impacts...nothing.
Managed to get a 1/2" breaker bar on with my 6 ft cheater (had to cut about 1/2" off the socket with my dremel!!). I thought for sure I'd get it then, but nope...bent 1 screwdriver in the flywheel...snapped the end off of another...
I'm gonna look for something stronger to stick in the flywheel. I don't really like putting that much load on the teeth though. That is where everybody else binds theirs up, correct? I don't see any other way to do it...
Next option is heavy duty air and impact...not sure where I'm gonna get those though...
This sucks ***...
[Modified by hankd, 4:30 AM 2/11/2003]
Old Feb 11, 2003 | 02:06 AM
niedejb's Avatar
I'd go ahead and get the crank holding tool (itd save your flywheel).
I wish I had one. Let me know and I'll take it off your hands when youre done.
Old Feb 11, 2003 | 05:20 AM
hankd's Avatar
I think I might do that...this one?
Where's the best place to get one? I already have to make a trip to the dealer to get that retainer and the antennae mast removal tool. Maybe somebody like Autozone rents them???
