are b18c pulleys and b16a pulleys the same???
Old Feb 7, 2003 | 07:03 AM
weezercrx's Avatar
Default are b18c pulleys and b16a pulleys the same???
i want to do an engine swap, but the pulleys on the b18c look a bit stuffed. i was wondering if i can use my pulleys on my b16a on the b18c? also can i use my b16a belts??
Old Feb 7, 2003 | 09:36 PM
joe_bocc's Avatar
Default Re: are b18c pulleys and b16a pulleys the same??? (weezercrx)
No, you can not use the GSR pullies on the B16. They have different part numbers. Also, you can't use the B16 belt because the two motors have different block heights so the belt would be too short.
freakie
Jan 5, 2004 09:58 AM
-CP-
Sep 30, 2002 09:02 AM
DOHC b16a VTEC
29
Jun 3, 2002 06:55 AM
