Does gas go bad??
Old Feb 7, 2003 | 03:01 AM
SjCiViCHB's Avatar
Default Does gas go bad??
Well i just heard gas goes bad after a long time of just sitting there. I have a full tank in my car, and my car has been sittin in front of my house for about 4-5 months now. I didnt know gas could go bad, and when my motor went i had a full tank. What can i do?? like i was told like stuff from the gas floats down to the bottom of the tank, is there a way i can clean that up? like if i pour something in it?? and is there a way to cipher(sp?) out the gas with like a mahine or sumthin? how do i cipher gas??
Old Feb 7, 2003 | 04:40 AM
piscorpio's Avatar
Default Re: Does gas go bad?? (SjCiViCHB)
You are supposed to add fuel stabilizer to your gas tank if you know it will be sitting for a long time. Im not sure exactly what happens if it sits for too long, something like it gels up?
Oh and its siphon gas. If you want to siphon your gas, you just stick a rubber hose in the tank, suck just enough to get flow started (you don't want to swallow gas) and make sure the other end is in a bucket or something. Also, you could just use the drain bolt on your gas tank and drain it that way.
Old Feb 7, 2003 | 04:43 AM
piscorpio's Avatar
Default Re: Does gas go bad?? (piscorpio)
One more thing, you may want to find out first how long it takes for gas to go bad on you. Im not sure, so maybe someone else could let you know if its no good after 4-5 months of sitting.
Old Feb 7, 2003 | 07:40 AM
Patrick's Avatar
^ He's right on.
Old Feb 7, 2003 | 08:55 AM
martini's Avatar
there is a drain plug on the gas tank...but if it's a full tank, that's going to be quite a bit of gas coming out of there...
4-5 mo should be fine, really. but you should take it easy on the car just in case (are you breaking in a motor anyways?)
as soon as you have used up a couple gallons, go top off the tank with some good gas, and keep doing that..
[Modified by martini, 9:59 AM 2/7/2003]
Old Feb 7, 2003 | 09:01 AM
ITC Racer's Avatar
Default Re: Does gas go bad?? (martini)
Gas that sits too long will start to turn to varnish. Old gas plugs jets and damages floats, etc unless treated with Stabil or someother material. How quickly this happens will depend on the quality of the gas and the environment it sits in.
If you put some stabil in the tank now, you will most likely save the gas in the tank but the gas in the lines and injectors cannot be treated since you must run the engine after treating the gas to get the stabil into the entire fuel system. If quality gas sits for less than a year, you will probably be fine or you can drain the system.
Hope this helps
Old Feb 7, 2003 | 05:09 PM
SjCiViCHB's Avatar
Default Re: Does gas go bad?? (ITC Racer)
so you guys think i will be fine if i just put some stabilizer in my gas tank asap, then i wont have to worry about it as much?? i only use shell or chevron gas. So thats whats most likely in the car.
Old Feb 7, 2003 | 05:18 PM
escocrx's Avatar
my car jus sat for 6 months. with the same gas. i'll worry about it never. haha
i jus started it up and went.
but dont listen to me. im not a tech. seems fine though
Old Feb 8, 2003 | 01:54 PM
SjCiViCHB's Avatar
Default Re: Does gas go bad?? (escocrx)
up...
so what do i ask for at the part stores guys??
Old Feb 8, 2003 | 03:53 PM
7PSI CRX's Avatar
Old Feb 8, 2003 | 05:05 PM
SjCiViCHB's Avatar
Default Re: Does gas go bad?? (7PSI CRX)
thanks alot. I hope thats not more then 10 bux.
for everyone who has helped.
Old Feb 8, 2003 | 05:08 PM
97civicdx's Avatar
Why is your car sitting for 5months?
Old Feb 8, 2003 | 05:42 PM
Nameless RB26's Avatar
Default Re: Does gas go bad?? (97civicdx)
Ciphering is easy.. I'd just do that. Don't waste money..
Put a hose into the tank and suck on the hose with your thumb on the tip of the hose in your mouth, then hold the hose DOWN below the tank area and it will pull the gasoline out into a bucket or something. It's easy. Might want to use a clear hose though, so you can see the gas coming towards your mouth.
Old Feb 9, 2003 | 12:07 PM
piscorpio's Avatar
Default Re: Does gas go bad?? (Nameless)
SIPHONING!!
I'm starting to feel a bit like shawnhayes.
Old Feb 9, 2003 | 04:43 PM
SIPHONING!!
Hey.. that's not a word I use very often.. but hahahahhaa, I guess I didn't even sound it out when I spelled that one. I'm way off..
Old Feb 9, 2003 | 05:08 PM
SjCiViCHB's Avatar
cause i blew my dseries motor. and im saving for my bseries swap.
i dont have a big enough gas container...so ill just buy that stablizing stuff.
Old Feb 9, 2003 | 06:44 PM
91DA9's Avatar
275,000 Original Miles on my stock, never opened D16.
Damn thats one strong timing belt!
Old Feb 9, 2003 | 10:15 PM
tilt's Avatar
Default Re: Does gas go bad?? (94IntegraGSR-OVR)
Half a tank of gas in a crx for more than a year and a half.... it started up fine but I would drain it if you have the option to.
Old Feb 10, 2003 | 06:40 AM
tpr's Avatar
tpr
If the tank is full and it has been less than a year it should be just fine. A full tank is better than one nearly empty. The reason is condensation. If the tank is full or nearly so then there is less air and with that less water vapor to condense on the inside of the tank with temperature changes. The Stabil is meant for small engines with small fuel tanks. It won't hurt but will do little over the short haul. How soon do you plan to ressurect the car?
Old Feb 10, 2003 | 11:53 AM
SjCiViCHB's Avatar
Default Re: Does gas go bad?? (tpr)
im trying to get the car up and running by next month. So it would probably be sittin for about 6months total after i get the car running. So do you guys think i should use that stabil? or should i just pass? cause i really dont feel draining out all the gas, plus i dont have enough gas containers for it.
Old Feb 11, 2003 | 06:05 PM
jwaked's Avatar
Use the stabil and then take it easy. Drive the car and don't step on it until you get new gas in there.
Jay
Old Feb 14, 2003 | 06:35 AM
CHK4TIX's Avatar
Default Re: Does gas go bad?? (jwaked)
i had about the same problem, the engine blew and i had just filled the tank that night. the car sat for 6 months. After i got the new engine in it, It started fine but i could tell the gas wasnt that great. I ended up puting in some gas treatment, which seemed to help. As soon as i could i refilled that tank. After i had gone threw 2 full tanks i also changed my plugs out and i could tell a difference
pepsi813
Honda CR-V & Element
May 19, 2019 12:41 PM
mahatma
Nov 27, 2006 08:14 AM
STN_Pat
Oct 2, 2004 07:02 PM
ekdriven
Jun 8, 2004 08:39 AM
wickedEFguy
Mar 4, 2004 10:38 AM
