getting correct parts for jdm b16a1
i was at a honda dealer today trying to price a timing belt for the b16, does the jdm take a different one? and am i supposed to ask for one from a 94-97 del sol vtec? i need to know cause people around here are telling me three different things! oh and what water pump also? thanks!
You can get the water pump and timing belt from a 94-97 Del Sol DOHC Vtec. Most of the parts are the same except for the dist. cap and rotor. Those you can get off of a 90-91 integra
If you need anything like a starter or alternator I would go with a 1990 integra. For the belt and water pump you could go with the delsol dohc vtec, but becarefully, autozone, pepboys and murrys gets the 1.6 sohc delsol confused with the dohc somtimes. Well atleast over here they do, I know murry's only carrys parts for the 1.6 sohc delsol. So if they don't have the part for the delsol, ask if they have it for the 1990 integra. Hope this makes senses
[Modified by 90blackcrx, 12:46 AM 2/7/2003]
for water pump/oil pump/timing belt you can get ANY b16 stuff (Del Sol DOHC vtec, 99-00 Civic Si)
clutch - 90-91 teg
most of the electrical stuff the teg works but the distributor. You need an actuall JDM b16a1 distributor.
clutch - 90-91 teg
cbmprelude
Aug 23, 2006 05:33 AM
GetawayInMoscow
Jun 27, 2005 07:43 AM
bluecrxsi
Feb 5, 2003 07:20 PM
