Need help please (woodruff key, crankshaft key way?)
Old Feb 6, 2003 | 03:34 PM
98civicEX's Avatar
Default Need help please (woodruff key, crankshaft key way?)
We're putting together the block and we can't remember if the crankshaft needs to keys or one? Just wanted to confirm? Can anyone help out on this? thanks in advance. I'm referring to part # 19, it says 2 needed in quantity, but it also looks like 3 is needed to fill the space.
[Modified by 98civicEX, 4:35 PM 2/6/2003]
Old Feb 6, 2003 | 04:49 PM
turbohonda's Avatar
Default Re: Need help please (98civicEX)
Only one key is used.
Old Feb 6, 2003 | 04:51 PM
94TealGSR's Avatar
One key, labelled #19 in the diagram.
Old Feb 6, 2003 | 07:43 PM
98civicEX's Avatar
Default Re: Need help please (94TealGSR)
actually i belive it's two...after messing w/ it, the timing belt pulley needed one, then the crank pulley did as well, one goes below the timing belt, then the spacer, then the other goes under the pulley. thanks for the help though guys
Old Feb 6, 2003 | 07:50 PM
94TealGSR's Avatar
I still say one. I only have one.
Old Feb 6, 2003 | 07:55 PM
IN VTEC's Avatar
It depends on whether you have a CKF sensor or not. I'm particularly sure when they started using them, but I've seen it on Robbie's '98 GS-R (neo1z). So, I'm guessing it was implemented either as an addition with OBD-II, or as a part of the major changes they made in 1998.
I didn't believe it at first too b/c I'd only worked on OBD-I B- engines for the longest time.
99blackdc2
Jul 28, 2006 07:23 PM
Anti-Drama Queens
May 6, 2006 07:00 PM
coldfiremx
Mar 5, 2003 04:18 PM
vtec69
Jan 16, 2003 08:37 AM
h46it
Mar 21, 2002 07:57 AM
