24.5 or 25"
One of these will be going on a set of Lenzo 13x7's. The 24.5's are 8.5 wide and the 25's are 8". Is there any problem putting the 8.5" wide on a 7" wheel? With right around 450whp is it worth while to go with the 25" slicks? One last question. I have to raise the front of my car up about 1.25-1.75" to fit the slicks on. Should I raise teh rear up also to keep the front and rear level.
Wider gives you more rolling resistance.
Taller gives you more rollout, but a lower Final Drive.
You gotta see how much the tires grow, also...If you get 25" high growth...they will be more like 26 -27...Low growth...26" prolly.
Suprdave
[Modified by Suprdave, 7:28 PM 2/14/2003]
Suprdave
I was running 24.5 and never realize that I was going to go faster with a 22/9/13 M&H. I do agree that a wider tire is much better.Another thing that counts is to have the proper gearing and the proper HP so that you can move big tires, I only have a 4.78 final drive and running over 250 HP and my car hooks real good I get low 1.5 60 foots.
My slicks came in today and I mounted one of them. I'm going to have to raise my car up about 1.5". I also have to swap out my brakes tomorrow to fit these 13's on.
MugenHonda
Aug 5, 2005 07:40 PM
