Check list for B18C swap
So all I need for a B18C swap would be a complete motor kit from HMO, a Del-Sol Vtec mount (if I want to keep the A/C), and.... anything else? Help a no0b out.. if you wish.
Motor, tranny, mounts from the teg and civic, axles, ecu, PR3 or P54 a/c bracket depending on year of your motor. IAB wiring will also depend on year of motor and car. You might have exhaust length issues but nothing a local shop or welder can't handle.
Engine, tranny, ecu, axles, shiftlinkage, and wiring harness will all be included in the "Swap" from HMO.
You will also need to get radiator hoses, throttle cable, and all the fluids.
