Does Brake Fluid Go Bad?
Old Feb 6, 2003 | 10:42 AM
CPR's Avatar
CPR
Default Does Brake Fluid Go Bad?
When I flushed my brake fluid, I only used up about 3/4 of the can. According to my co-worker, my leftover fluid is useless since the open container causes the attraction of moisture. T or F?
Old Feb 6, 2003 | 10:47 AM
Stroker
Guest
Posts: n/a
Default Re: Does Brake Fluid Go Bad? (CPR)
T
Old Feb 6, 2003 | 10:48 AM
thk's Avatar
thk
Members Only
Well, this is what Andie @ Cobalt Friction told me (IIRC) ...
After the container is opened, it has basically a shelf life of 6 or so months.
I think if it's in a metal container like ATE products, you might be able to make it last a bit longer.
Take the remaining fluid and flush out your clutch resevour.
Old Feb 6, 2003 | 11:48 AM
Floyd's Avatar
Default Re: Does Brake Fluid Go Bad? (thk)
T
Brake fluid, especailly race fluid, is hygroscopic and will absorb moisture over time.
I'd buy a new bottle for your next flush.
Old Feb 6, 2003 | 11:51 AM
TypeR 01 886's Avatar
Default Re: Does Brake Fluid Go Bad? (Floyd)
good info guys.
Old Feb 6, 2003 | 12:01 PM
PhucNguyen57's Avatar
MOst places do keep that stuff on the shelf for a while, so I dont know, maybe after it is opened it will absorb some moisture. What kind of fluid is it? Unless it is Castrol SRF I would think it would be easily/inexpensively replaced. JUst write it off as a loss.
[Modified by PhucNguyen57, 1:02 PM 2/6/2003]
Old Feb 6, 2003 | 12:04 PM
Batoutahell's Avatar
Default Re: Does Brake Fluid Go Bad? (PhucNguyen57)
(in a James Earl Jones voice) "Today we investigate....when good brake fluid...goes bad!"
Old Feb 6, 2003 | 12:06 PM
eviltwin's Avatar
Default Re: Does Brake Fluid Go Bad? (TypeR 01 886)
good info guys.
Old Feb 6, 2003 | 07:13 PM
Art Vandeleigh's Avatar
True. dont use old brake fluid.
moisture = bad
Corksil
Jun 28, 2011 02:24 PM
2k1 SSM GSR
Mar 23, 2005 10:02 AM
kommon_sense
Jan 4, 2005 11:46 AM
SilverDc2
Jun 6, 2004 08:54 PM
JSIR
Apr 27, 2002 10:27 PM
