90 Civic Si - "Rio Red" or "Phoenix Red"?
I'm trying to buy paint for a car I haven't bought yet. I know 88-91 CRXs were available in "Rio Red", and I'm nearly sure that the Civic is the same color, but the parts store catalog says "Phoenix Red". Could someone confirm? Multiple web searches only revealed CRX colors, not Civic Si.
Thanks!
Thanks!
I will do that as soon as I get it ... next week. Thought someone here might know.
I'm a planner. Hell, while I'm on this subject, here is the maintenance I plan for the car (which I'm just buying as a beater/rallycross car). Any thoughts?
REPAIR
CV boot
Motor mount
Exhaust
T-BELT & COOLING
Timing belt
Tensioner
Alternator belt
Water pump
Radiator
Coolant
VALVETRAIN
Adjust valves
Spark plugs
Valve cover gasket
Spark plug tube seals
Valve cover bolt seals
BRAKES
Bleed brakes
Adj rear brakes
TUNE-UP
Wiper blades
Fuel filter
Trans fluid
Oil filters
Diff fluid
Hatch props
Alignment
COSMETIC
Paint wheels
Paint trim
Paint bumper
REPAIR
CV boot
Motor mount
Exhaust
T-BELT & COOLING
Timing belt
Tensioner
Alternator belt
Water pump
Radiator
Coolant
VALVETRAIN
Adjust valves
Spark plugs
Valve cover gasket
BRAKES
Bleed brakes
Adj rear brakes
TUNE-UP
Wiper blades
Fuel filter
Trans fluid
Oil filters
Diff fluid
Hatch props
Alignment
COSMETIC
Paint wheels
Paint trim
Paint bumper
Skip01
12
Nov 4, 2003 08:41 AM
