homemade turbo question
i just got one question on running custom turbo on dohc zc, once i part it all together if i run low boost(6-7) with a manual boost controller, do i need a different ECU and also what about the injectors, is stock ok or what?
edit: this isn't the site I was thinking about but it should have some useful info:
http://thenew.gamesbbs.com/~turbosi/twinturbo.html
[Modified by SIRX, 12:36 PM 2/6/2003]
do a search on afc hack, itll explain what you can do as far as fuel needs, you can use a stock ecu. All you'll need is 440cc injectors off a dsm or they can be off a supra(but you'll need the plugs) and a afc.
