anyone run a spool on the street?
Old Feb 6, 2003 | 07:05 AM
sickda6's Avatar
Default anyone run a spool on the street?
i just got a pro-drive spool and i wanna drive on the street on weekends. anyone know if this is bad for my trans. btw- its a cable trans.
Old Feb 6, 2003 | 07:15 AM
rOby's Avatar
Default Re: anyone run a spool on the street? (bigdon)
i think the general consensus is not to run a spool...most just use a quaife
Old Feb 6, 2003 | 07:21 AM
turbo Si's Avatar
Default Re: anyone run a spool on the street? (rOby)
Some say it stutters only when making slow turns like into a parking space or something, and drivability is ok...............although I am not sure.
I would like to know more though!
Old Feb 6, 2003 | 07:31 AM
sickda6's Avatar
Default Re: anyone run a spool on the street? (turbo Si)
well, ill be able to tell you, its goin in this weekend. i think it will be fine.
Old Feb 6, 2003 | 07:49 AM
Robb's Avatar
I wouldnt suggest it. I have one in my car. As long as you are going at least 5-10 mph its not to tough to turn, but anything slower and its a nightmare to manuver around. Good Luck.
Old Feb 6, 2003 | 08:19 AM
turbo Si's Avatar
Default Re: anyone run a spool on the street? (Robb)
That's the same thing I was told........for the price it's a tough decision!
Old Feb 6, 2003 | 08:54 AM
Drewh22a's Avatar
we been running welded diff in our cars on the street since 98.. its similar to running a spool... ive driven both on the street, car with spool and car with welded diff. theyre both the same. the only difficult part is making u turns, u gotta go wide. besides that DO NOT LET GO OF THE STEERING WHEEL! KEEP BOTH HANDS ON IT AT ALL TIMES. if u never driven a car with a spool or welded diff, you'll figure out why. lol
its no biggie, takes about a day or 2 to get used to it. i personally think it intimidates people when your turning and the tires chirp.. good luck man!
[Modified by 90boreh22a, 5:55 PM 2/6/2003]
Old Feb 6, 2003 | 09:03 AM
sickda6's Avatar
Default Re: anyone run a spool on the street? (90boreh22a)
thanks man, its in no way street leagal, but im drivin it anyway.
Old Feb 6, 2003 | 09:52 AM
kentucky accord's Avatar
ive had multiple welded diffs and dont see it as any big deal on the street. you get used to it fairly quick. not only are they fun at the track but they are fun on entrance/exit ramps....the diff pulls you right through the turn...no more baking off that inside tire under full throttle blasts.
Old Feb 6, 2003 | 10:25 AM
highbrid's Avatar
Default Re: anyone run a spool on the street? (kentucky accord)
i used to run a spool in my hatch, with no power steering. You get tired of it after a while. Its hard to get into parking spaces sometimes, and it tears up your tires. Its great for traction though. We took the tranny out of my car and put it into my friend's car so he could race with it. He has power steering in his car and it feels semi-normal with power steering.
Old Feb 6, 2003 | 11:43 AM
turbo Si's Avatar
Default Re: anyone run a spool on the street? (highbrid)
With the response i'm hearing here, I might just get a Pro Drive myself!
Old Feb 6, 2003 | 11:51 AM
sickda6's Avatar
you should, i paid 490 shipped, although i am a dealer. its still cheaper than a quaife.
Old Feb 6, 2003 | 04:24 PM
BudaKai's Avatar
Default Re: anyone run a spool on the street? (jtrbocrx)
You guys that welded your differentials. What exactly in there did you weld? Any good sites from hoe to's on this?
Old Feb 6, 2003 | 05:02 PM
sickda6's Avatar
Default Re: anyone run a spool on the street? (tzsir)
heres a pic
[Modified by sickda6, 2:03 AM 2/7/2003]
Old Feb 6, 2003 | 07:01 PM
MotorMatrix.com's Avatar
I am a bad person
i believe on the welded diff you weld the spider gears. a lot of the guys around here run a welded diff on the street. i was going to runt he spool myself but i had this fear of breaking an axle on the highway racing and going into the median or across to oncoming traffic. well i bought a quaife but i havent used it yet. i cant wait.
Old Feb 6, 2003 | 08:29 PM
Default Re: anyone run a spool on the street? (MotorMatrix.com)
weld the spider gears or just run a good bead between the teeth on each side. some people weld the gears to the case was well, i never have but i havent used them in a high HP Honda application either. i have welded them to the carrier sides on rear ends of full size trucks/jeeps, etc., with good luck.
FWIW, i broke an axle on the street with my old welded up accord tranny and it shoot across lanes of traffic or anything. also, if i hadnt had the diff welded, i wouldnt have been able to drive it home. that one axle pulling got me back home and on the road again.
Old Feb 7, 2003 | 12:40 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
I also have a cable tranny. Crx its small. So should i go with a spool or LSD. FOr those who have spools on there street cars. Is it really a bitch to turn. I have stage 4 dss axles. I really do not think ill break a axle on the street.
george34
39
Jul 17, 2006 04:11 PM
paulzy
Aug 30, 2005 06:42 AM
LUCKYDRAGSTA
Aug 19, 2004 05:57 PM
DragRaider
Sep 4, 2003 01:15 AM
-iLLuZioN-B18C1
Dec 16, 2002 11:42 AM
