b18c1 civic.......suspension questions
Old Feb 6, 2003 | 12:34 AM
vw-honda-hatches's Avatar
Default b18c1 civic.......suspension questions
Should I use civic shocks and integra springs? or integra both?
Thanks for the help.
Old Feb 6, 2003 | 01:53 AM
Default Re: b18c1 civic.......suspension questions (vw-honda-hatches)
the shocks i want to get (kyb agx) have the same part number for 92-95 civic and 92-95 integra......
Old Feb 6, 2003 | 05:03 AM
VTECVillain's Avatar
Ususally the struts are the same since the Civic and Integra are similar. The springs though, they usually have a stiffer spring rate for the Integra. I would go with Integra rate springs if possible.
Old Feb 6, 2003 | 05:19 AM
ok
H&R race springs for my 95 civic cx drops the vehicle.....
2.5-front
2.0-rear
While the race springs for a 95 integra drop it
2.0-front
1.75 back
My car is a 4x4er and I am positive I want to do the civic height, but can i change or get my own spring rates? Does any body know the rates for h&r race for 95 integra and civic?
Old Feb 6, 2003 | 03:01 PM
up
Old Feb 6, 2003 | 08:48 PM
eg6sir-s's Avatar
from what i know and been told the springs rates are the same with civic and integs...its the struts that are diffrent...just upgrade your front shocks to integ spec and you should be good.
Old Feb 6, 2003 | 09:51 PM
GTlvr82's Avatar
Default Re: b18c1 civic.......suspension questions (eg6si)
If I use the Tein Flex w/ EDFC will it work for semi-track, and daily driving for my hatch?? I was also going to use the JIC setup but Im not sure
Old Feb 6, 2003 | 10:04 PM
Default Re: b18c1 civic.......suspension questions (GTlvr82)
integra front struts are different? they have the same part numbers for kyb and tokico.
Old Feb 6, 2003 | 10:10 PM
eg6sir-s's Avatar
even better, you dont have to upgrade.
Old Feb 6, 2003 | 10:37 PM
sooooooooooo people are wrong on here when they say get integra spring rates and suspension?
Old Feb 6, 2003 | 11:18 PM
h and r race spring part numbers......
95 civic - 50145-88
95 integra - 51863-88
maybe i should just call h and r
Seye
Suspension & Brakes
Oct 2, 2006 07:31 AM
IntegraJCEN
Suspension & Brakes
10
Mar 17, 2006 10:26 AM
egsleepercivic
Jan 18, 2005 01:14 PM
HX_Guy
Nov 5, 2002 07:21 PM
