Does 93 & 94 B18B use a different water pump than 95+?
Old Feb 5, 2003 | 08:22 PM
PandaBear's Avatar
Default Does 93 & 94 B18B use a different water pump than 95+?
AHMotor charge me twice as much on a 97 pump and say 93/94 is not compatible, is that true?
Old Feb 7, 2003 | 08:58 PM
Flamenco-T's Avatar
Default Re: Does 93 & 94 B18B use a different water pump than 95+? (PandaBear)
they all the same if you use LS water pump, use LS timing belt, if you GSR water pump, use GSR timing belt
thirsk66
10
May 22, 2013 02:26 PM
woadiestyle
Mar 25, 2009 04:06 PM
1slowcrx
Nov 17, 2004 03:24 PM
Dancing is Forbidden
Oct 10, 2003 01:24 PM
CIVICNONVTEC
Jun 2, 2003 07:23 PM
