Installing Toda cam gears, should I use the bolts that came with the gears or the factory bolts?
Old Feb 5, 2003 | 08:07 PM
PYITR821's Avatar
Default Installing Toda cam gears, should I use the bolts that cam with the gears or the factory bolts?
I am going to be installing Toda cam gears with my stock ITR cams....should I use the bolts that came with the cam gears or should I use the factory bolts..or does it even matter..
Old Feb 5, 2003 | 08:09 PM
B2FiNiTY's Avatar
Default Re: Installing Toda cam gears, should I use the bolts that cam with the gears or the factory bolts?
I don't think it matters. My spoon gen 2 didn't even come with them but then my spoon gen 1 did.
Old Feb 5, 2003 | 08:12 PM
SergEK's Avatar
I used the nice bolts supplied by toda on my ITR cams.....they work nice and offer that JDM silver bling factor Dont lose the cam gear setting sheet they give you either (its all in Kanji anway) but the diagram's are pretty self explanitory.
Can you imagine "Spoon" doesnt supply those bolts with their gears (which we know are Toda's) Guess if you buy "Spoon" cam gears you gotta pay for the "Spoon" cam bolts seperately
Old Feb 5, 2003 | 08:15 PM
jonas's Avatar
just incase:
Old Feb 5, 2003 | 08:17 PM
PYITR821's Avatar
nice!
Old Feb 5, 2003 | 11:02 PM
Kid1320's Avatar
my friend's spoon first gen cam gears came with bolts but the head of the bolts stuck out too much and he couldnt pu the valce cover back on
[Modified by Kid1320, 12:03 AM 2/6/2003]
Old Feb 5, 2003 | 11:52 PM
PYITR821's Avatar
I don't know if there is any difference but I have the second generation cam gears.
[Modified by PYITR821, 12:52 AM 2/6/2003]
Old Feb 6, 2003 | 07:07 AM
sneakychaos's Avatar
Pretty sure that the stock bolts will rub your valvecover, I'll see if I can find an old thread. BTW, bolts w/ Toda camgears are 17mm, stock are 14mm.
Old Feb 6, 2003 | 07:14 AM
Black R's Avatar
25 Year Member
.....just use the toda bolts.
But you might want to replace the little allen-head bolts for adjustment.....
sgT's Avatar
sgT
its not all kanji.....
spoon doesnt supply bolts because they dont need them. Didnt notice that the
design was slightly different did you??
Old Feb 6, 2003 | 12:34 PM
SergEK's Avatar
The Toda design is just fine for me. Obviously "Spoon" agree's or they would have chosen another manufacturer to make their gears for them. As far as I have "seen" the only difference was "Spoon" engraved where TODA POWER is engraved...I doubt spoon's redesign affects performance seeing as how you can adjust the stock toda by the 0.5 degree plus I bought the Toda's new for $250 so I cant complain
Old Feb 6, 2003 | 01:55 PM
sgT's Avatar
sgT
spoon gears have a recess in the face so that the stock bolts will work with no problems.
Old Feb 7, 2003 | 08:12 PM
SergEK's Avatar
Hmm I can see recessing the gear for the stock bolts to fit but wouldnt it be easier to just add the new bolts? Or is it more of a ploy to "change" something to Spoon spec's and charge more money?
OT: Have you noticed the Toda's cam key to cam fitment being off at all? When I installed the cam gears back on the cams the fit was a little tight...wondering if my batch was machined a little differently or if this is common?
Old Feb 7, 2003 | 11:50 PM
sgT's Avatar
sgT
they are the same price from what i see, actually spoon is cheaper here.
plus because you canuse stock bolts its less to worry about. either way they
are the same gear prettymuch.
ive had both spoon and toda gears have a slightly tight fit. nothing terrible though
Old Feb 7, 2003 | 11:59 PM
PYITR821's Avatar
what do you guys mean by the Toda gears being "a tight fit"?
[Modified by PYITR821, 1:02 AM 2/8/2003]
Old Feb 8, 2003 | 03:25 AM
Ausmith's Avatar
The when you put the woodruff key, gear, and cam together it is a tight fit meaning it won't just all slide together easily.
I hit the key area of the cam with a little emory cloth and then put a drop of oil on the key itself. Got everything lined up and then use the bolt to bring it all together.
I beleive the problem is worse when you have a brand new, lets say Toda, cam.
Clinton Shultz
Feb 13, 2016 06:03 PM
Ferrell
Jul 26, 2003 06:48 AM
SpoonFed
Jan 31, 2002 01:07 PM
IgniteTeg
Sep 27, 2001 09:03 AM
