Are these vacuum lines hooked up correctly?
Old Feb 5, 2003 | 03:01 PM
T_Rex's Avatar
Default Are these vacuum lines hooked up correctly?
Could you guys help me figure out if these vacuum hoses are correct? I have a CRX with a first gen B16. I need it to be right for emissions testing. Thanks a lot!
[Modified by T~Rex, 4:01 PM 2/5/2003]
Old Feb 5, 2003 | 07:06 PM
T_Rex's Avatar
Default Re: Are these vacuum lines hooked up correctly? (T~Rex)
bump
Old Feb 6, 2003 | 08:51 PM
T_Rex's Avatar
I want to use this diagram as a reference--is it correct?
Old Feb 6, 2003 | 09:19 PM
1SlowB16EF's Avatar
all looks good to me!
Old Feb 6, 2003 | 09:28 PM
T_Rex's Avatar
Default Re: Are these vacuum lines hooked up correctly? (1SlowB16EF)
The pics or the diagram? Or do you mean both?
Also, in the diagram it shows a tube that goes to the intake, but I already have the intake tube going to that hole on the valve cover...
[Modified by T~Rex, 10:31 PM 2/6/2003]
Old Feb 6, 2003 | 09:46 PM
eg6sir-s's Avatar
just as a reminder sometimes the smog officers are not so forgiving when you use non oem hoses...so if you can get the proper lines and dont use those lines when your inspection takes place.
Old May 14, 2003 | 02:33 PM
T_Rex's Avatar
Default Re: Are these vacuum lines hooked up correctly? (eg6si)
Could anyone else confirm the correct hook up of the vacuum hoses? My idle is high, so I'm thinking it could be the vauum hoses...but I guess there could be a leak, even if they are hooked up correctly, couldn't there?
fredrock
Acura TL, RL & ZDX
Apr 28, 2018 01:58 PM
ryanevansoh
15
Sep 2, 2009 09:55 AM
crxb18a1
Mar 1, 2005 12:45 PM
T_Rex
May 15, 2003 11:11 PM
