msd ignition problems
Old Feb 5, 2003 | 01:27 PM
b16 pwrd ek's Avatar
Default msd ignition problems
I just hooked up a msd sci ignition and blaster 3 coil and now i keep blowing my ignition fuse in the fuse box under the hood. I don't know what it could be if anyone has any suggestions on what the problem is let me know.
Old Feb 6, 2003 | 05:46 AM
Default Re: msd ignition problems (b16 pwrd ek)
has this ever happened to anyone else. if so please help because this is about to drive me crazy
Old Feb 6, 2003 | 09:59 AM
PhatOptimo's Avatar
If it happens when you connect the battery then make sure your connecting the battery terminals in their proper location.
Old Feb 10, 2003 | 02:04 PM
pornstarSR's Avatar
i had this problem one night on my msd 6al, it was great it was 12:30 in the morning, mine was the power wire it was grounding to the body, so i had to fix that, but i wouild check both the ground and the power wire make sure they have good connections and are not jiggling about
Old Feb 10, 2003 | 02:09 PM
qcoffey's Avatar
Default Re: msd ignition problems (pornstarSR)
I would double check the wiring. I have had this setup for almost two years without a single flaw. Sounds like either the ground or power wires aren't hooked up properly. Post what colors you got hooked up where and mayber we can help some more.
ludeatomics
Mar 8, 2016 09:11 PM
ludeatomics
Mar 5, 2016 05:51 PM
almerricking
Dec 3, 2007 05:05 AM
Performance Freaks EH
Dec 11, 2006 12:17 PM
DEMNTD1
Oct 16, 2005 04:24 PM
