How to fix: Shift Linkage Problem
Old Feb 5, 2003 | 12:37 PM
631 Teggy's Avatar
Default How to fix: Shift Linkage Problem
Modified by 631 Teggy at 9:42 AM 9/20/2005
Old Feb 6, 2003 | 12:47 PM
egNYC's Avatar
Default Re: How to fix: Shift Linkage Problem (631 Teggy)
well I would check to see if my linkage isnt loose anywhere. If not loose then it could be throwout bearing is causing the hard shifting in the the gears, its not fully disengaging the clutch. worse case scenario is your gearbox is bad.
92hatch!
Transmission & Drivetrain
Feb 21, 2009 11:28 PM
92hatchboi
Oct 22, 2007 06:13 PM
vandersmissenc
Jun 4, 2007 07:44 PM
Egone
May 25, 2005 12:35 PM
G U E C O
Oct 15, 2003 06:23 PM
