almost done with swap into 88 crx and question about front mount
Old Feb 5, 2003 | 11:45 AM
dutchman5's Avatar
Default almost done with swap into 88 crx and question about front mount
i m post it again and asking about the mount.. i just brought the mount kits for integra engine and it s work great but they only send the three engine mounts.. but what about the front mount???? i did install the b18a motor into the crx and put the crossmember annd it s doesnt fit so i hammer it and it s fit...i dont know if i suppose to put the front mount??
Old Feb 5, 2003 | 12:13 PM
Jeff C's Avatar
Default Re: almost done with swap into 88 crx and question about front mount (dutchman5)
You dont need the front mount. I am not using one.
Old Feb 5, 2003 | 08:35 PM
MONSTERZC's Avatar
you cannot use the front mount you need to shave it down or just cut it off don't worry about you need it
Old Feb 6, 2003 | 12:48 AM
NirSpec1's Avatar
you cannot use the stock front mount, the bracket on the crossmemeber does not line up. If you want one and what to run a large header you can get the place racing crossmemeber for around $250 which comes with the front mount. We are using one in a b20 vtec turbo set up and works very well
Peace
90redintegra
Dec 8, 2006 06:17 AM
B18aHatch
Aug 19, 2005 06:50 PM
cubancrx
Apr 5, 2004 11:38 AM
