testing clutch?
Old Feb 5, 2003 | 10:34 AM
91_hatch_si's Avatar
Default testing clutch?
what is the way to test if the clutch is still good?, is it something like stop the car , and pull up the e-brake, and shift to second, then what? if it dies out is it good?
Old Feb 5, 2003 | 10:37 AM
Hondasaurs's Avatar
Default Re: testing clutch? (91_hatch_si)
Hold the gas to the floor when you shift at redline. You'll find out really quick if it slips.
[Modified by ZC_CRX, 2:39 PM 2/5/2003]
Old Feb 5, 2003 | 10:43 AM
SIRX's Avatar
Default Re: testing clutch? (ZC_CRX)
start out in first and side step the clutch at 6,000 rpm. se what happens . But really try driving in second gear about 15-20 mph (what ever speed is below your power range) then do some full throttle take offs at that speed. . In other words the engine should be lugging alittle and then floor it from what-ever speed your at. How long have you been driving that you don't know when a clutch is getting weak??? Or just launch the car and take it up to red-line in every gear (1-3) there should be no slippage. If you have any doubts about the clutch it's probably on its way out
Old Feb 5, 2003 | 10:58 AM
Vinceg99's Avatar
Default Re: testing clutch? (SIRX)
Along with those ways you can also shift from first to fifth and see if the rpms jump up or if the car just bogs down.
Old Feb 5, 2003 | 11:01 AM
muskrat's Avatar
Take out engine/tranny, then separate and look at the clutch, shouldn't take long.
Old Feb 5, 2003 | 11:08 AM
SIRX's Avatar
Default Re: testing clutch? (muskrat)
nahh just drop the tranny it'll save you a little time
Old Feb 5, 2003 | 11:53 AM
Jeff C's Avatar
I have been told to take off like normal (from a stop) in 5th and if you can, then your clutch needs replacing.
Old Feb 5, 2003 | 12:59 PM
RexB16's Avatar
Default Re: testing clutch? (Jeff C)
if the clutch isn't holding power anymore, you WILL notice it, unless you are a complete moron. so when this happens guess what? thats right, you get to replace it.
Old Feb 5, 2003 | 01:00 PM
RexB16's Avatar
Default Re: testing clutch? (RexB16)
oh ya, and make sure you make use of the clutch adjustment cable. something that EVERYONE SEEMS TO FORGET ABOUT!
ac_attak
Sep 5, 2008 09:53 AM
petrv
Aug 17, 2004 02:10 AM
highschooler
Jun 5, 2003 08:11 PM
civicheaven151
Jul 7, 2002 07:04 PM
NNtegGs
Sep 21, 2001 09:58 PM
