I searched, I still need more info on B18A wiring into a 91 DX hatch.
Old Feb 5, 2003 | 08:33 AM
ridestrt's Avatar
Default I searched, I still need more info on B18A wiring into a 91 DX hatch.
I have a 1992 B18A motor, ECU, and wiring harness. I want to put it into my 91 Civic hatch. How hard is it to run the ECU that I have instead of switching it it OBD-0. Or is it easier to make it OBD-0? Also, I have a B16A1 tranny that I am going to use, can I use the flywheel off the B16A1 motor? Which clutch do I need?
Old Feb 5, 2003 | 04:08 PM
paybac4223's Avatar
Default Re: I searched, I still need more info on B18A wiring into a 91 DX hatch. (NMcivicEF)
which ECU do you have... you mean the ECU that came with the swap? most likely you will have to convert the car to obd1 i think hasport sells a kit of that nature...not sure.. you may want to try a search for a better answer
Old Feb 6, 2003 | 05:50 AM
ridestrt's Avatar
Default Re: I searched, I still need more info on B18A wiring into a 91 DX hatch. (paybac4223)
The ECU says PR4 if this means anything.
Old Feb 6, 2003 | 06:06 PM
SiR831's Avatar
what color do the ecu plugs look? Grey?
Old Feb 6, 2003 | 07:06 PM
VTECVillain's Avatar
You can buy or make an OBDO to OBDI ECU adapter. Using the OBD0 parts is the easiest.
That tranny will put extra stress on the B18A motor due to it's shorter gears. If you do a lot of high speed driving or long distance driving, then I wouldn't recommend it. I have a 92 GSR YS1 cable tranny with the 96 B18B1 in my 91 CRX and it pulls really good but it also revs a little higher than I wish it would while cruising on the interstate.
[Modified by VTECVillain, 11:06 PM 2/6/2003]
Old Feb 8, 2003 | 11:50 PM
ridestrt's Avatar
Default Re: I searched, I still need more info on B18A wiring into a 91 DX hatch. (SiR831)
The actual plugs on the ECU are grey. Is this what you were talking about?
Old Feb 9, 2003 | 11:45 AM
ridestrt's Avatar
I have a 1991 civic SI that is wrecked and has a b16a in it. It has a PR3 ECU with black and green plugs on the ECU. Can I use this ECU? Will the B16A injectors and distributor work if I decide to go OBD0? Thanks
Old Feb 10, 2003 | 02:09 AM
vspec12's Avatar
New User
pr4 just means its a LS ecu, as far as your harness goes just use a Si harness or a OBD 0 or OBD1 harness they will both work and you wont have to rewire, just make sure your distributor connection hooks up good
Old Feb 10, 2003 | 04:34 AM
The PR3 ECU is made to work with a DOHC VTEC motor only. If you want an ECU that will plug into your car harness without using an ECU adpater harness, then you need the 90-91 PR4 Integra ECU. You mentioned that the LS ECU you have, has the grey plugs. That is no doubt a 92 or 93 PR4 which is OBD1. It will only work if you rewire your ECU plugs to OBD1 style or get an ECU adapter harness.
Old Feb 10, 2003 | 04:41 AM
Default Re: I searched, I still need more info on B18A wiring into a 91 DX hatch. (vspec12)
You CAN NOT use a Si harness in an 88-91 DX/STD. The MPFI Si harness has different plugs at the shock towers where the engine harness meets the cabin harness than the DPFI DX. If it were that simple then people wouldn't always be talking about doing DPFI to MPFI wiring. If you plan on giving advice, at least give correct advice or seem somewhat intelligent.
Old Feb 10, 2003 | 05:53 AM
ridestrt's Avatar
Default Re: I searched, I still need more info on B18A wiring into a 91 DX hatch. (VTECVillain)
Can I use the B16A distributor and injectors since I need to go to OBD0?
Old Feb 10, 2003 | 09:10 AM
RenoRacing's Avatar
https://honda-tech.com/zerothread?id=404891
here's a diagram my friend made
Old Feb 10, 2003 | 10:15 AM
You can use the distributor, although it will have to be modified to fit. Most people use the 90-91 LS distributor on their first gen B16 since there is no direct bolt-on US counterpart. I've never done this, but I know it involves cutting off one of the mounting legs. I think it also limits your range of ignition timing unless you widen one of the holes. The injectors will work with no problem.
Since you already have a B16 in the other car, you will need to use the injector plugs, resistor box, large distributor plug to replace the square DX one and any extra wiring that you'll need to convert it to MPFI. Since you have the B16, why not use the head and make an LSVTEC with the LS block?
Old Feb 10, 2003 | 11:24 AM
ridestrt's Avatar
When the car with the B16a was wrecked the radiator support was smashed into the head, which cracked it. I know I could just put a new head on it but I think the B18A with the J1 tranny will be fun until I can get a different tranny and go turbo. I think I will try and find a 90-91 teg distributor so I dont have to do any modifying. So all I need now is the distributor and a 90-91 PR4? Thanks for all the help.
Greyknight1138
Engine Management and Tuning
Mar 10, 2014 05:00 AM
Zack Gunther
Apr 16, 2013 06:10 AM
notburton06
Jan 30, 2007 08:08 AM
MxJones92
Jan 25, 2006 12:23 PM
91hatch_on17's
Jan 31, 2003 08:34 PM
