what are the signs for a bad intake manifold gasket?
Old Feb 5, 2003 | 06:29 AM
IC x Prince's Avatar
New User
Default what are the signs for a bad intake manifold gasket?
When I accelerate, I get a small buzzing noise. Not like an AEM or any type of intake sound. I have my stock airbox and a pipe in place of my resonator (DIY ice box) and RU-2820 K&N air filter. Is the noise i'm hearing a bad gasket? TIA.
Old Feb 5, 2003 | 06:57 AM
JimBlake's Avatar
Default Re: what are the signs for a bad intake manifold gasket? (UltraPrince)
Intake manifold gasket would leak worse at idle, cause that's when the vacuum is strongest. Vacuum leak would probably give you an unstable idle.
Try putting the resonator back onto your intake pipe. The reason the resonator is there is for the noise...
Old Feb 5, 2003 | 07:00 AM
New User
Default Re: what are the signs for a bad intake manifold gasket? (JimBlake)
it has been off for welll since i bought the car new...I just started to here that sound maybe a month ago. I have a wierd idle, kinda up and down, but just slightly, not like an out of wack TPs ( i had that problem before too). it is enough to annoy me, but not enough to trouble shoot. how bad would the idle be? I saw it in another post before and he said it was his IM gasket. I just didn't know how bad the idle was.
Old Feb 5, 2003 | 08:02 AM
ajchen's Avatar
i have a cracked gasket and a big nasty vacuum leak... my idle sounds like race cams....except i dont have race cams.
EDIT: you asked how bad the idle is. mine goes from 700 - 1500 real aggressively. you can DEFINITELY tell.
if you're hearing that whistling sound, pop your hood and listen real closely to see where the sound is coming from. look around for a leak - it should be most prominent at idle if its a gasket issue.
[Modified by ajchen, 5:03 PM 2/5/2003]
Old Feb 5, 2003 | 08:06 AM
New User
Default Re: what are the signs for a bad intake manifold gasket? (ajchen)
ok thanks, that might not be it. mine sounds normal at idle and hardly any idle jumping. i go from 700-1100 at the most, and very slowly. the sound i'm hearing might just be the air resonating trought the tube. i dunno...i guess i'll continue to ignore it. thanks for the help.
Old Feb 5, 2003 | 09:43 AM
ajchen's Avatar
check for other vacuum leaks... like i said, best way is to open your hood and listen really carefully. the weird idle might be from something else...
good luck.
BIGef
13
Oct 27, 2012 12:25 PM
singlecammin
Jan 20, 2011 07:20 PM
SimplyTron
Jan 26, 2006 08:19 PM
Jowee
14
May 15, 2005 09:02 AM
ULTRA911
Mar 4, 2003 10:00 AM
