Milling ITR head 0.020" and its affect on static CR
USDM ITR block w/USDM ITR pistons and ITR crank
ITR head milled 0.020"
stock head gasket
What kind of numbers are you guys getting for static CR?
-kenji
stock head gasket
-kenji
and how do you know that its correct?
its already got one calc wrong. whos to say that they arent all wrong?
Steve - How did you arrive at 11.3-4?
Every time someone ask about 'what the compression will be', everyone says "it SHOULD be around x-y". No one ever has a definite, exact answer.
Since the stock ITR compression is correct on c-speed's calc, I'd say by changing only one variable (the change made by milling 0.02"), that it is improbable that this change would make for an incorrect calc. I could very well be wrong...
No offense intended whatsoever. I'm just wondering where people get their estimates/exact figures in these cases.
[Modified by Chris N, 1:11 PM 2/5/2003]
reason for using the word SHOULD is you never have exact measurements.
differences in gasket thicknesses, actual deck and cylinder head heights will
play a role in determining the EXACT CR.
ArmedFelon99
15
Oct 21, 2009 11:38 AM
TwoPointZero
Jul 23, 2004 03:46 PM
