suspension questions - springs
Old Feb 5, 2003 | 05:38 AM
serious's Avatar
Default suspension questions - springs
these questions are all for a 90 civic hatch.
1. is it possible to switch the front and rear springs?
2. what are the spring rates on the stock springs on a civic si and dx?
3. how would the car ride with 350 ft and 450 rr? looking for a ride just a little stiffer than stock (lots of potholes around here).
Old Feb 5, 2003 | 05:53 AM
keithv's Avatar
Default Re: suspension questions - springs (serious)
are you talking about stock springs? if so, you could feasibly do it, but i don't think you'd want to. the front are linear with a higher spring rate and the rears are progressive. progressive springs in the front wouldn't work to well.
i have either 350f/400r or 400f/450r mated with koni yellows and the ride is much stiffer than stock. if you want a stock-ish ride, go with the eibach pro-kit springs. i have them on my teg with agxs.
Old Feb 5, 2003 | 06:08 AM
serious's Avatar
Default Re: suspension questions - springs (breaka_1_9)
do you know the spring rate on the eibach pro-kits?
Old Feb 5, 2003 | 06:24 AM
keithv's Avatar
this might not give you exactly what you need, but it might help.
http://php.indiana.edu/~bchang/Pics/...ate_Table.html
Old Feb 5, 2003 | 08:00 AM
tpr's Avatar
tpr
Find a 91 LX in the boneyard. I just swapped the front and rear springs on my '88 DX. It keeps the stock ride height (w/ZC motor + 50-60 Lbs) in front and rear but is a firmer ride. I also added Suspension Techniques sway bars (22 mm F/R) with KYG AGX shocks. It corners flat and yet my old bones don't get jarred too much. I tried Integra springs but they are too tall and even when cut down offer to harsh a ride for my taste. LX sprigs with a good swaybar front and rear and good shocks is what I have setteled on.
vinuneuro
Suspension & Brakes
Oct 17, 2007 11:25 AM
vincepru
Suspension & Brakes
12
Oct 14, 2005 10:48 AM
92CivicLSI
17
Nov 11, 2004 02:04 PM
B18C5-EH2
14
Dec 4, 2003 04:41 AM
garados
Jan 31, 2002 06:28 PM
