Unplugging EVAP purge solenoid dangerous?
Old Feb 5, 2003 | 05:19 AM
VTHokie's Avatar
Default Unplugging EVAP purge solenoid dangerous?
Right now I have my EVAP purge solenoid unplugged and i was wondering if this was dangerous? I was brousing clubsi, and someone on there said
"Your cannister can get saturated with fuel. Eventually, it will overspill with fuel and leak out causing a possible fire hazard. Not to mention VOC compounds released into the atmosphere. "
Does anyone know if this is true?
Eric
Old Feb 5, 2003 | 09:52 AM
sgT's Avatar
sgT
Default Re: Unplugging EVAP purge solenoid dangerous? (VTHokie)
i guess all those hybrids running around with no evap hooked up are spilling fuel all over the place
ive had my evap unplugged for a few years now. no problems
Old Feb 5, 2003 | 10:44 AM
VTHokie's Avatar
Cool, yeah i know alot of guys running it unplugged, i have mine totally removed. I just wanted to make sure that it was ok. Thanks.
Eric
Old Feb 5, 2003 | 11:04 AM
ajchen's Avatar
how do you run it unplugged without throwing a CEL code?
Old Feb 5, 2003 | 11:08 AM
VTHokie's Avatar
Default Re: Unplugging EVAP purge solenoid dangerous? (ajchen)
I have a p28 obdI ecu.
Old Feb 5, 2003 | 12:15 PM
blykins's Avatar
Banned
Wheres it located? I'd like to know if mine is either plugged or unplugged.
Old Feb 5, 2003 | 12:20 PM
Chris N's Avatar
Andrew, the OBD2 Evap/Purge system runs differently than the OBD1 system. Unplugging it stops the hunting idle some people get when you are using an OBD1 ECU. Since the ECU isn't looking for the OBD2 solenoid, no CEL. Not sure what the differences between the two EVAP systems are, though.
blackeg
May 1, 2016 09:01 PM
SmaTTeRLegion
May 29, 2013 07:36 PM
my99ekcoupe
16
Sep 1, 2010 09:45 PM
2DoorBandit
Apr 1, 2008 04:46 PM
Asahi
Nov 17, 2003 07:30 AM
