Clutch/Neutral
Old Feb 4, 2003 | 07:57 PM
vtec.dc2's Avatar
Default Clutch/Neutral
Besides obvious differences, what is different between clutch being pushed in or just placing in neutral? As far as engagement/position of parts from clutch/flywheel/pressure plate assembly to clutch pedal.
Old Feb 5, 2003 | 08:30 AM
vtec.dc2's Avatar
Default Re: Clutch/Neutral (vtec.dc2)
ttt
Old Feb 5, 2003 | 08:51 AM
TsunamiZC's Avatar
maybe this will help ...
press the actuate button
http://www.exedy.co.jp/eweb/prd/qtmv/clutchmovie_e.html
Old Feb 5, 2003 | 09:08 AM
vtec.dc2's Avatar
Default Re: Clutch/Neutral (tsunami_zc)
thanks for the link... - that part i understand.. when pedal is pressed, clutch is pushed back from flywheel, but what happens when you place gearing in neutral.. whats different about that? - for some reason i can't picture that..
Old Feb 5, 2003 | 09:10 AM
AssPenny's Avatar
When the cluth is pressed in, it is not spinning the main shaft (well it's spinning a little, but not connected to the motor). When the car is in neutrual and the clutch is not pressed, the motor is spinning the main shaft, however, since its not in gear, the car does not move
Old Feb 5, 2003 | 10:02 AM
TypeR 01 886's Avatar
Default Re: Clutch/Neutral (AssPenny)
to put it in a way that you can imagine.
Neutral = you standing there looking at a spinning rod; you are not spinning with it
IN GEAR = you grab spinning rod and start flying in circles with it.
Old Feb 5, 2003 | 10:14 AM
RiCE On IcE 2's Avatar
Default Re: Clutch/Neutral (TypeR 01 886)
check out http://www.howstuffworks.com
Old Feb 5, 2003 | 10:40 AM
ITR 00-1567's Avatar
New User
Default Re: Clutch/Neutral (RiCE On IcE 2)
F'n pop-ups on EVERY page.... Ahhh...
Old Feb 5, 2003 | 05:34 PM
Default Re: Clutch/Neutral (ITR 00-1567)
yea pop ups suck but it's a relaly good site for info on a lot of stuff
Old Feb 5, 2003 | 07:48 PM
vtec.dc2's Avatar
makes sence now.. thanks for everyones help
Brandon H.
Nov 18, 2012 09:14 AM
Chiller
Nov 4, 2006 04:11 PM
SSJSubgeta
Oct 22, 2005 12:20 PM
FK00GSR
Mar 31, 2005 06:55 AM
Razor
Jul 19, 2002 08:33 AM
