mini me setup...hard?
to put on a d16z6 head onto my d16a6 block would that be hard?
what exactly do u have to do
especialy if im running a t25 turbo setup with ported hf manifold
i would plan on running a shift light to activate the vtec...ghettorigged
Direct bolt up. Just have to take you head off, get all of the head gasket off the block and the Z6 head. There is also a plug in the rear top of the head that needs to be removed. Replace the head gasket. Torque to spec in order. The Exhaust manifold will bolt right up. Intake may have to do some changes to the coolant lines. Add a V-tec switch ex. V-AFC, Fields, MSD RPM switch, shift light, tach anything like that. Start it up and go from there
[Modified by zCivic, 1:42 PM 2/5/2003]
patastinky
Feb 15, 2005 10:51 PM
