H22 swap into 5g Automatic ?'s
What ecu to use? the (hypothetical) car is an LX and i was wondering if an US ex ecu will work, the engine would be JDM
Im told the JDM h22 will fit the us A/T, can i just use a fields or V-afc?
thanks
thanks
well the accord auto tranny sucks, add 55hp to it and shift at higher rpms wouldn't be good for it. unless you manually shift, the accord auto ecu will still shift at accord shift points. the jdm auto is the way to go it's stronger and has firmer shifts.
i have a 96 auto H22
i can help you in all the ways i can
email me mkteller8@aol.com
you could use a ex ecu from the accord
you could use any auto 92-95 h22 ecu
or just use the jdm h22 auto ecu
if you come across a 96 h22 auto either usdm or jdm
let me know i ll trade ya a ton of products or whatever for it
whaaaa r u talkin, u should u the jdm h22 auto ecu for the best gear ratios
as far as what ecu to use, you could use an accord (vtec) auto ecu
a JDM auto h22 ecu would be best though.
Just do it the right way, buy a complete swap, use the right ECU, none of this half-assed bullshit. Get a manual too, automatic honda's suck.
whats up, i have heard that there is something that you can do to the computer of the car by messin with the gear ratios and adding horses without even putting a single aftermarket piece on your car. if this is true someone e mail me back if they know what the hell thats all abouyt and could possibly tell me how to do that.
Peace, brandon
Peace, brandon
I also have a accord lx auto but wanna convert it to manual h22. How hard and how much labor cash wise am I lookin at? Will 4 grand be enough for motor and labor?
[Modified by roydogg, 9:11 AM 2/6/2003]
i had a h22 plus auto manual done, labor cost me 1,300. extra 5sp parts was like $800 including a new act clutch.
I wouldn't mind spending that much as long as it's done right with no problems.
I also have a accord lx auto but wanna convert it to manual h22. How hard and how much labor cash wise am I lookin at? Will 4 grand be enough for motor and labor?[Modified by roydogg, 9:11 AM 2/6/2003]
oh yeah cause the swap shouldnt cost you more than 2200-2500 shipped and then youll have close to 1500-1800 for the converstion.. somewhere in the search is a full list parts of what you need..
this may sound sick, but i spent close 6,000 when all was said and done. don't forget maintenance parts and new bolt-ons. figure at least another 1,000-1,500 for this stuff and anything that may come up.
let's see i bought:
97+ lude aem cai
93-96 lude greddy header
carsound cat
act clutch
timing belts
water pump
knock sensor
97+ lude p/s bracket
valve cover gaskets
cam seals
header gasket
fuel filter
ngk wires
ngk plugs
spark plug seals
honda mtf fluid
remanufactured accord 5sp axles (luckily i got these for free)
distributor cap
rotor
upper and lower radiator hoses
there's alot of maintenance items that need to be attended. i don't see the point in buying a oem clutch, when my most peoples intentions with a h22 swap are to exceed what the oem clutch was designed for. it's easier to spend more up front, then to say damn i wish i did that later on. now i wish i did a quaife lsd and cam gears which to have installed now will cost too much v. if i did it with the swap, probably free.
97+ lude aem cai
carsound cat
act clutch
timing belts
water pump
knock sensor
valve cover gaskets
cam seals
header gasket
fuel filter
ngk wires
ngk plugs
spark plug seals
honda mtf fluid
distributor cap
rotor
lol ok i can see where six grand went. i was figuring ppl get their auto to manual swap parts from a yard of so. i am sure ppl want the best, but then again. your getting out of an auto to a stick. aint that just good enough
LOL
i guess i have it lucky. where i can hope to the local yard and pull what i want. since they are a bunch of rednick's with big trucks. they laugh when i head over there for stuff. they are like..'daing car is suppose to run forever huh'. i smile and say yeah. then walk and pull parts and sensors and stuff. they look and say. what ya got there? awh that junk? lol so i walk out with it.
one day they will understand!!
LOLi guess i have it lucky. where i can hope to the local yard and pull what i want. since they are a bunch of rednick's with big trucks. they laugh when i head over there for stuff. they are like..'daing car is suppose to run forever huh'. i smile and say yeah. then walk and pull parts and sensors and stuff. they look and say. what ya got there? awh that junk? lol so i walk out with it.
No_Limits_Accord
Jan 26, 2019 04:54 PM
prjctCIVIC
Jun 14, 2002 05:34 AM
.A auto h22 would save alot of labor money but what fun would that be.
